What Did You Do To (or With) Your Cayenne Today ?
#286
What yr and model do you have. I'd love a before and after audio. I work down the street from hank and stopped in for a brief talk, but havent heard the mod.
#287
Drove an hour in the blowing snow that stopped about the time we got home. A few back roads were snow packed with 2-3 cars in the ditch. Glad I left the snow tires on through the 60 degree temps we had last week!
#288
09 GTS, 6 mt. I hear really no difference, normal to sport mode with the stock exhaust now....just way too quiet. I’ll attempt some sound clips, as a newbie to attempting any such thing, I make no promises
#289
I'm interested to get your take on just the secondary bypass pipes.
#290
Drove her to Columbia and let her stretch her legs a bit
#292
I have the Fabspeed secondary cat bypass pipes - non resonated - and it wasn't enough for me. It's a nice improvement outside the car, but barely noticeable from inside the car. Combining that with a performance muffler (cargraphic) is what got the sound to where I was happy with it. Still perfectly acceptable at highway cruising speeds, but now properly aggressive under hard acceleration. I also did an HHR CAI which makes the turbo noises and blow off valve sounds more noticeable too - now a performance sound symphony.
I am looking for no 'rasp' while increasing 'rumble' through out the RPM range. Preferably only louder when accelerating. I am not against a $4,000 test purchase and install, but would rather not need to go that route.
#293
Thanks guys. I have the turbo, so no Sport mode for me. The only thing i can say is i like the sound of my exhaust on cold morning starts. Then it settles down to barely audible.
#294
Any noticeable smell with the 2nd cats removed?
#295
No. There also aren't any downstream O2 sensors from the secondary cats so removing them has no effect on engine management, fueling, or anything else - they're completely redundant for emissions purposes only. You also won't believe what they weight once you get them off.
#297
That's a beautiful and well put together Cayenne. I don't normally like black wheels but with the polished ring to break them up and the black door handles and window trim, it all works extremely well together. Clear side markers would look great!
#298
Today I changed the front diff and transfer case oils: Lucas Oil 75W-140 for the diff and Porsche OEM for the transfer. Pretty easy and quick job thanks to all the DIYs available despite the really hard to loose fill plug in the differential but a few kicks made it.
Story is that I had some whine in the mid-forward cabin and thought it was time for the oils but unfortunately there was only one bottle of Lucas available and I'll do the rear when they stock back. The whine has disapeared up to 90-100 mph when it becomes alive again although less noticeable. I guess a thicker oil will make the diff happier when the real hot weather comes in Qatar.
After I finished the job I took the car for a full wash including the belly without the covers because it had a lot of sand and dust from the desert trips and dusty weather and tomorrow I`ll put the covers back afger checking for leaks.
And this puts another check mark in the to-do list.
#299
Thanks Pete, Yes totally agree, completely black painted wheels need some contrast the Silver lip is perfect. The clear front corners will be next.
