Vcds How to
Old 12-29-2018 | 06:17 AM
  #31
tats's Avatar
tats
Does anyone know the accessible control modules and their addresses for the 957 with VCDS?
I have vcds-lite unlicensed at the moment and trying to determine what additional functionality I'll get with the licensed VCDS-Lite version - at the moment with an ebay cable with pins 3, 7, 15 bridged I can read the Auto Trans, Transfer Case, Instrument Cluster and the Mirror Controller.
I do not pirate software and this is only to determine what VCDS to get. When I asked Ross-Tech about buying a full 3-vin version from them they said not supported here's a link to Duramteric. But this can't set the auto-headlight coding. So I'm suspecting the $99 version won't give me access either but want to check first before I order.
Old 12-29-2018 | 06:20 AM
  #32
Kev90sc1's Avatar
Kev90sc1
5th Gear
With the lite and the generic cable you won't be able to do CAN, I have the full version 3 vin, I can look at all the modules besides the ecm (v8 turbo) and the Headlights.
Old 12-29-2018 | 06:36 AM
  #33
tats's Avatar
tats
Thanks Kev - what MY is your turbo? Thanks.
<edit> ah just saw you have an 09...sweet
Old 04-12-2019 | 10:12 AM
  #34
Shabaz Latif's Avatar
Shabaz Latif
2nd Gear
Originally Posted by Stringbag
Everything works.
Code all modules.
I have icarscan too, which is good, but not as many functions as vcds.
hi sorry if this has been asked of you
I have a vag com cable and I have a y cable can you share a guide on how to modify the y cable so that my vag com will let me code my cayenne please
Old 11-08-2019 | 03:48 PM
  #35
carbonm's Avatar
carbonm
Has anyone gotten this to work on a 958 cayenne?
Old 01-01-2020 | 12:10 PM
  #36
Djcc's Avatar
Djcc
Would also like to know if someone tried on 958...
Old 02-26-2020 | 09:28 PM
  #37
Whimpy's Avatar
Whimpy
7th Gear
How to get VCDS working on your cayenne:
You need to swap the Porsche k-line to the vw k-line position. (Porsche on pin3, vw on pin7)
easiest way is a obd y cable and some crimps.
Dont go soldering your expensive vcds cable!
google OBD pinout to make sure that you connect the right wires.
Can anyone tell me which pin 15 connects to 3 and 7..is it pin 15 from the VW side or the Porsche side?
Old 02-27-2020 | 12:36 PM
  #38
Stringbag's Avatar
Stringbag
They are the same....
Old 02-27-2020 | 12:53 PM
  #39
Stringbag's Avatar
Stringbag
Just to be clear, you don’t need to do anything at all to get VCDS working with DME and transmission modules. just plug the VCDS cable straight in.
this is because a GENUINE VCDS cable has two k-line pins 7 and 15.
the cayenne uses 7 for the DME/transmission and 3 for the rest.
So,
You need to EITHER swap pins 3 and 7 over via an adapter like I did (because I didn’t want to mess with either my Cayenne wiring or my genuine cable wiring), OR connect 15 (from the VCDS cable side) to 3 (on the vehicle side).
counterfeit VCDS cables only have one k-line (usually).
The following 4 users liked this post by Stringbag:
CayenneScotland (12-17-2020), gaconways (08-14-2022), hopsis (02-28-2020), Whimpy (02-27-2020)
Old 02-27-2020 | 06:43 PM
  #40
Whimpy's Avatar
Whimpy
7th Gear
thank you.. Stringbag
Old 02-29-2020 | 12:35 PM
  #41
Whimpy's Avatar
Whimpy
7th Gear
Not working for me...guess i wired it wrong....so pin 3 from the female side of the adapter that plugs into the Cayenne to pin 7 male adapter that plugs into the VCDS cable to the computer....pin 15 is not used?
Thanks Bob.
Old 02-29-2020 | 01:53 PM
  #42
Stringbag's Avatar
Stringbag
Hi Bob
have you tried it with no adapter at all?
is it a real VCDS cable?
Old 02-29-2020 | 02:25 PM
  #43
Whimpy's Avatar
Whimpy
7th Gear
[QUOTE=Stringbag;16452340]Hi Bob
is it a real VCDS cable?[/QUOTE
Hi...yes the VCDS cable works fine...green light comes on and I can use it as normal...just when I plug in the adapter the light goes red...think I've wired it wrong...need a pin out of the original connector I guess.
But I'm thinking pin 1 is the top left pin on the female adapter??
My adapter cable is identical to yours..
And yes it's the real VCDS cable I bought with the software.
Old 03-01-2020 | 08:13 AM
  #44
Stringbag's Avatar
Stringbag
I’ll post a picture of my VCDS cable for you
Old 03-03-2020 | 09:51 AM
  #45
Stringbag's Avatar
Stringbag
So, I modified my splitter cable to see if I could get all the modules talking in one go.
Success! As per my post above, all you need to do is connect 15 (from the VCDS cable side) to 3 (on the vehicle side). Simple! (forget 7 was ever mentioned...).
This is what I got on my autoscan (mine is an 03 - later years have more modules and therefore a bigger list - I have made my autoscan specific to my vehicle) (nb I have removed my VIN & cable serial number from the scan):
Tuesday,03,March,2020,13:09:35:XXX
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: XXX
Data version: XXX
www.Ross-Tech.com
VIN: WP1ZZZ9PZ3LA80XXX License Plate: XXX
Mileage: 189690km-117867mi Repair Order:
Chassis Type: 9P (9P - Porsche Cayenne)
Scan: 01 02 03 05 06 08 15 16 17 19 22 34 36 46 65 68 76 76
VIN: WP1ZZZ9PZ3LA80884 Mileage: 189690km-117867miles
Address 01: Engine Labels: None
Part No SW: 8TE 4AS N20 000 HW: Hardware No
Component: 0041850144FG8TE4G 20021
Coding: 0001133
Shop #: WSC 12345 000 00000
VCID: 59EC85FE45012F6FEEB-5184
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 AA
Component: AL 600 6Q 0310
Coding: 0012328
Shop #: WSC 71569 144 00001
VCID: 6D84C12EA189A3CF123-5184
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379
Component: ESP ALLRAD MK25 0104
Coding: 0023813
VCID: 76B6EE42D4EF6017E39-5184
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 131 F HW: 5WK 470 22
Component: Kessy 6120
Coding: 0147617
Shop #: WSC 73752 144 00001
VCID: 2412E40A32F3A2878DD-5184
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No: 7L0 959 760
Component: Sitzverstellung 0201
Shop #: WSC 00000 000 00000
VCID: 77A8E346D3E5191FF8F-5184
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L5 907 040 AB
Component: Klima - SG R/L 2512
Coding: 0000020
VCID: 6FB8DB26ABB551DF20F-5184
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
008 - Implausible Signal
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 B
Component: 1 Airbag 8.4E+ H07 0643
Coding: 0008241
VCID: 221EE21228E7ACB7FF1-5184
Address 16: Steering wheel Labels: None
Part No: 7L5 953 549 B
Component: Lenksäulenmodul 1601
Coding: 0001312
Shop #: WSC 31414 000 00000
VCID: 3D24316EB159F34FE23-5184
Address 17: Instruments Labels: None
Part No: 7L5 920 980
Component: KOMBIINSTRUMENT RB4 2610
Coding: 0029404
Shop #: WSC 73752 144 00033
VCID: 74B2D44AC2937207DDD-5184
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70BAD85AB68B4E27395-5184
Address 22: AWD Labels: None
Part No: 0AD 927 755 M
Component: TRANSFERCASE 1083
VCID: 45D4598ED989BB8FBA3-5184
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 C
Component: LUFTFDR.-CDC- 3C1P1 3539
Coding: 0011110
Shop #: WSC 00003 896 00001
VCID: 33301756871D353F047-5184
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzverstellung 0203
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 C
Component: JA HSG 3214
Coding: 0001041
Shop #: WSC 73744 000 00001
VCID: 3C223C6AAA43FA47D5D-4B00
Subsystem 1 - Part No: 7L0 959 701 E
Component: Tuersteuergeraet FS 0104
Subsystem 2 - Part No: 7L0 959 702 E
Component: Tuersteuergeraet BF 0104
Subsystem 3 - Part No: 7L0 959 703 B
Component: Tuersteuergeraet HL 0104
Subsystem 4 - Part No: 7L0 959 704 B
Component: Tuersteuergeraet HR 0104
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0018
Subsystem 6 - Part No: 7L5 951 171
Component: Innenraumsensor 0019
Address 65: Tire Pressure Labels: 7L0-907-273.lbl
Part No: 7L0 907 273 F
Component: Reifendruckueberw. 0014
Coding: 0730313
VCID: 3534294E89692B0F2A3-5184
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 G
Component: Front Wiper 2416
Coding: 0000003
Shop #: WSC 31414 000 376832
VCID: 382A207A9E7BD667315-5184
Address 76: Park Assist Labels: None
Part No: 7L0 919 283 C
Component: 40 Einparkhilfe 0507
VCID: 36362E42946F2017239-5184
1 Fault Found:
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
End----------(Elapsed Time: 04:41, VBatt start/end: 13.9V/13.9V)-----------
Quick Reply: Vcds How to
