Going from 18" to 17" wheels
I guess I am doing the reverse of what most others are trying to do. I am thinking about downgrading from 18" to 17" wheels, for three reasons:
1. lower unsprung weight
2. softer ride
3. 18" are just too large, optically (IMHO)
Two questions that I hope you can help with:
1. Which 17" Porsche wheels can I use? What widths and offsets will work without spacers?
2. What are the lightest 17" Porsche wheels? I currently have the 18" Turbo Look wheels, anybody know how heavy these wheels are? How do they compare to the 17" 996/Boxster wheel for example?
Thanks very much!
Gary
2. softer ride
Thanks very much!
Gary
18" Turbo Look are the heaviest--I think high 20s if not just over 30s in the rear. The Twist/Design wheels are a dime a dozen and are light low 20s. The Boxster S II are supposed to be the lightest of the factory 17s--very low 20s. Another reason to go for 17" wheels is that the tires are much cheaper. You can afford to go through stickier tires a lot more. 18" is definitely stiffer than 17" but there is an even bigger difference in tire construction across brands/tires. Going to 17" you can also go to something stiffer as well as stickier. I think 17.5" would be just about right as far as looks
Does Porsche make a hollow spoke in a 17"? You can also rummage through http://www.wheelweights.net/ and then see if the manufacturer makes a wheel with the Porsche bolt pattern.
Bro
Bro
DO NOT GO TO 17 INCH WHEELS. You will regret it,I can almost gaurentee it. Having the 18 inch Turbo Twist wheels give the car a much more aggresive look compared to any 17 inch available( I went from 17s to 18s). You may want to check out the Moda R6 model,they look VERY nice on Boxsters if you want to go to 17s.
Bro
Bro
If you are going for 17", be aware you can (and should) run 996 wheels. They require a spacer in the rear, but the extra width is nice to have to shoehorn some extra rubber on.
Thanks for all the replies!
What I've been able to find out so far re widths and offsets is the following:
18" Turbo Look II: F - 8x18/50 R - 10x18/47
18" Carrera 5spoke: F - 7.5x18/50 R - 9x18/52
17" Boxster S II: F - 7x17/55 R - 8.5x17/48
17" Turbo Twist 996: F - 7x17/50 R - 9x17/55
Does anyone have more info about other Porsche wheels? I'd love to compile a list.
The wheelweights.net database is not so helpful, because they don't list Porsche wheels by their proper name (e.g., they list "Boxster 17" - which wheel would that be? Lots of Boxster 17" wheels around...)
I like the Boxster S II wheel, but if you calculate the clearance of that wheel (I am using http://marksink.com/tire_wheel_offset/offset.html), it turns out that they require spacers (else they'd be too far inward). And spacers add weight again...
Just a thought, but though spacers add weight, a wheel with the correct offset will have material around the hub that is in effect a spacer attached to the wheel with the same weight consequences.
Wheels of the same type with different offsets should have the same weight.
Originally Posted by Irishdriver
This is not logical, the offset is different by the middle being attached to the rim at different depths, not by adding material to the centre.
Originally Posted by arenared
Is your application a 986 Boxster? If so, then I don't know why any factory Boxster 17" wheels would need spacers.
Interesting comments re spacer weight and weight of diff. offset wheels.
Which ones are the Boxster Design/Twist? I can't find them on wheelenhancement.
Arenared, just out of curiosity, what wheels have you tried, and which ones did you like best?
Gary
Jay, those are commonly called Turbo Twists, but Porsche calls them Turbo Look (I). There is also a Turbo Look II. I think these names are to differentiate them from the hollow-spoke which are just called Turbo (non-Look) from the 993 Turbo. I think the other common wheels like on lowside67's are commonly called Turbo Twist, but I think Porsche calls them Carrera or Boxster Design.
I looked up some old posts and here's what I found: Boxster S II are 17.8 lbs F and 19.6 lbs R. That is #$%& light. The Boxster fitment Turbo Look wheels are 24.4 lbs F and 29.3 lbs R. The 10" ET40 Turbo Look are 31.1 lbs. The narrowbody are 29.3 lbs.
