2012 TTS
I have read that the ball joints on the turbo actuators can become corroded and lose functionality over time and so I wanted to get under the car and lubricate mine. The ball joints are not easy to access and the can of lubricant spray that is recommended by Porsche has only a short small diameter nozzle.
I had a piece of small diameter silicone tubing (fuel tubing for small radio controlled aircraft engines) and a piece of wire that I taped to the tubing and was able to direct the lube directly at the ball joint and deliver a couple of drops without making a huge mess. I would give the joint a shot then move the actuator a few times to pull in the lube and repeat a couple of times.
Then I put a piece of a paper towel on the end of some long forceps and cleaned up the excess around the joints.
Hope this helps someone
Bill
Reason: .
What are the symptoms of them seizing up? Any straight forward test that could be performed while driving?
I was going to say that you could observe the boost pressure readout but that may not be true as I think the readout is theoretical and not actual. If the linkage isnt working correctly I would assume that you would not get the boost/horsepower that you should. Others here know more about this than me.
Under the car you can push on the ball joint and the linkage should operate smoothly n both directions. The passenger side linkage moves up from its resting position, the driver side moves down.
Bill.
There is the possibility that turbochargers may have been installed on which the ball joints on the adjustment mechanism for variable turbine geometry can become corroded.
As a result, the adjustment mechanism can become stiff as vehicle mileage increases, thereby resulting in a delayed response from the turbochargers
WD solvent will flash off instantly and leave very little high pressure/temp lube which is required for the ball and socket. This area of the turbo can see 970C max before the ECU shuts down thing (high limiter)
Good information! I typically don't use it as a grease but more so as a rust breakdown lol but as long as they hold out until I figure out what turbo's I'd like to go with I'll be happy
The factory recommended lubricant is shown in the opening message. WSP5040. I had to buy it through a dealer and it was $65 for the 400ml spray can.
bill
bill
Anyone tried antiseize for this purpose? Seems like the job is primarily hi-temp anti-corrosion and secondarily some lubrication of the joint. Seems like a good nickel or copper antiseize would work fine in that application - - works on brakes...
