OFFICIAL DSC SPORT DISCUSSION FORUM
#452
no worries, car, and laptop O.S (Mac+vm vs Windows natively) aside, it appears as though there is a problem with the f/w updater app accessing the DSC vs. the Tuner app...
curious if anyone has managed to update their DSC's firmware... if anyone has can they describe their environment (Windows, Mac, VMWare, Parallels, which COM port etc)?
- Larry
- Larry
#453
Late getting into this discussion. I'd love to see an Android interface. I've always got my phone with me. Any idea of the current units can be upgraded to Bluetooth?
#454
I did a little superficial investigation into the feasibility of doing this ... it pretty much all depends upon the (continuing) dependency on the SiLabs CP210x USB to UART driver ... since including this driver into Android requires a build of the underlying Linux kernel to include that driver, it pretty much makes an Android app untenable for general usage...
https://www.silabs.com/documents/pub...otes/AN809.pdf
Not having any insight into the bluetooth interface that the DSC exposes its impossible to determine if the CP210x USB-UART driver is still required (or not) ...
Regards
- Larry
#455
DSC Kit Ready to Install
All the bits have arrived. Time for installation into my 2007 GT3RS Pumpkin. Along with the complete RSS Tarmac kit (incl engine mounts), 997.2 GT3 shifter, numeric cables and Function-First transmission bushings, I should have the chassis starting to take shape.
#456
From a fellow 997.1 GT3 owner, stock 3.6 engine, DSC/Tractive, TPC sway bars, Guard 40/60 LSD kit, on 245/305 NT01's. First time on track with the newly installed suspension in advanced race group. Good stuff!
#457
Anyone running Windows 10 with auto updates having difficulty Writing to the DSC Box?
Previously I was able to Reset Board, Write and Read maps using a Win10 laptop. But suddenly the Write function now stalls mid-process and returns a "Timed Out" error message after approx 30 seconds (I can still Reset Board and Read installed DSC box maps). I can use an old XP laptop to fully communicate with the DSC box so that seems to eliminate the DSC box and USB cable as problem sources and points the finger at the Win 10 laptop's software and Tom agrees.
There was a Win 10 update (KB4087256) installed Feb 15 which was when the Write function first failed. I have uninstalled DSC Tuner and SilLabs USB interface, and then reinstalled (rebooting laptop after each uninstall and reinstall).
Now I appreciate the update timing may be indicative of nothing but I am clasping straws here trying to get it working correctly again.
Any thoughts/experiences that can be shared would be appreciated.
PS I have been a Mac user since Lisa and left MS at MS-DOS so have very little knowledge of the WinTel world so please include the"obvious"
#458
DSC and Tractive equipped 997 GT3 sets new NASA GTSU qualifying lap record at VIR!
Watch this beast conquer the curbing and putting the power down!
https://www.youtube.com/watch?v=NgMF...ature=youtu.be
#459
I'm a little confused by your recent newsletter "DSCsport just released all new DSCsport utility software that eliminates many of the problems associated with installation of driver software. This is an entirely new software that makes it easier for all DSCsport owners." and "NEW: Our new standalone Utility software. In order to install the new Utility software you must remove your old DSCsport drivers from your computer. "
So what does this mean for us that have been using the software up to this point, and created our own pdts files? Is the only difference between the old and new software is that it is more stable (I never had any issues), or are their new features? Thanks,
#461
The newer DSC software (version 1.7.1) adds more vehicle types to the selection and adds velocity function, which neither of these new features apply to 997 cars.
If you want you can download version 1.7.1 and still use your pdts file(s). Like I said, the new features do not affect 997 cars.
There's nothing wrong with keeping the older software. I still have the very first version on my desktop, and 1.4, 1.6, and 1.7. I only use the 1.7 when I read/write file for 991's, Corvette's, Camaro's, and GT350's.
For the few of those who have trouble with the third-party USB driver the new package eliminates that extra step.
#462
Received 2,012 Likes
Looks like something I need / want for my TTS.
Hmmm!
Hmmm!
#463
I am not sure why I seem to have been the only Win10 user with this problem other than it might have been a particular combination of OS build and Updates.
Anyway after absolutely no help from SilLabs I had a MS Certified guy check the Laptop and interface but he was unable to determine the root cause. So I had Win7 installed on the laptop and low and behold it all worked again - so no more MS updates destabilising third-party drivers/devices... it is my only MS laptop and will remain lonely and unconnected to my network.
I have a possible cause in mind however.. a developer posted on the SilLabs help forum that he had observed the baud rate being changed on the SilLabs interface by a Win10 update forcing it to communicate at 9600 rather than the 57600 his target device was expecting - the effect was to stop communication. SilLabs said they would look at it but if a valid issue it would likely be addressed with a bunch of other fixes as and when.
#464
I'm still unable to update the firmware on my unit via my win 10 64 bit laptop. There is a new "faster" firmware out for the 997.1 and I can't install it. The firmware program just can't find the box on the COM port.
#465
have you downloaded the latest installer app (1.8.3) from DSC and uninstalled the SIlabs USB/UART driver???
