997 GT2/GT3 Forum 2005-2012
GT3 Picture Thread
Old 05-12-2015, 07:54 PM
  #466
sixtosune
sixtosune's Avatar
Here's our little Atlas Gray GT3 on a Gray day, sitting next to its roomate "the sedate one"
Name:  911s Santiago 2013 HiRes.jpg
Old 05-13-2015, 10:33 AM
  #467
Megathumper
Megathumper's Avatar
Targa Tasmania 2015
Car 170 - Sideling - April 29
Old 05-13-2015, 11:00 AM
  #468
Megathumper
Default Targa Tasmania 2015
Car 170 - Queenstown - May 01
Old 05-14-2015, 11:27 PM
  #469
Speeds5
Speeds5's Avatar
^ fantastic pic!
Old 05-15-2015, 06:59 AM
  #470
Ur20v
Ur20v's Avatar
in a fantastic country- awesome roads like some in Wales or Scotland
Old 05-18-2015, 07:43 PM
  #471
redmonkey928
redmonkey928's Avatar
The 3.8 is all set and ready to go back in.
Pinned coolant lines, LSD rebuilt, new clutch/LWFW, new water pump/thermostat, Sharkwerks coolant elbows, injectors/intake ports cleaned, new BMC filter/serp. belt/spark plugs.
Waiting on M&M RSR full exhaust coming from overseas now, and it will be ready to rock
Old 05-18-2015, 08:59 PM
  #472
Ur20v
Ur20v's Avatar
I note your belt run is possibly incorrect (below the alternator and AC where it passes betwin the idler and tensioner) - it is possible to route the belt two ways but only one is correct to a 997 yours is the 996 way in the photo above.
Will post the correct way in a minute...
Old 05-18-2015, 09:05 PM
  #473
Ur20v
Ur20v's Avatar
Default Belt run
You can suffer slip or possibly throw a belt.
Image is from 997.1 manual but should be the same for your motor...Please check
  #474
audipwr1
audipwr1's Avatar
I note your belt run is possibly incorrect (below the alternator and AC where it passes betwin the idler and tensioner) - it is possible to route the belt two ways but only one is correct to a 997 yours is the 996 way in the photo above. Will post the correct way in a minute...
Damn nice eye
Old 05-18-2015, 09:33 PM
  #475
redmonkey928
You rock, thank you sir!
There was limited routing info on Mitchell software and that appeared to be one of the ways we were finding, went on alright, but prefer to use the correct method.
As always, appreciate the info.
Old 05-18-2015, 09:47 PM
  #476
The Greek
The Greek's Avatar
That was an epic catch....
Old 05-18-2015, 10:30 PM
  #477
sin911
sin911's Avatar
That was a great catch for sure!
Redmonkey, did you do anything about the actuator bolts? You are aware of the potential problems I presume.
Old 05-18-2015, 10:31 PM
  #478
jonwb
jonwb's Avatar
see what I mean? THIS FORUM IS THE BEST!!!
Old 05-19-2015, 12:06 AM
  #479
Evolved Rs
Evolved Rs's Avatar
Sound clip of that exhaust is also required
Old 05-19-2015, 12:32 AM
  #480
redmonkey928
Yes, that is the only item still being debated. Either buying one of Jamie's dampers or pulling the bolts and re-torquing with proper loctite are the options.
Anyone have thoughts there?
Definitely, Ill post the first start
RSR headers w/200 CEL cats, side deletes, and center muffler all in M&M stainless.
+1 on that!
Quick Reply: GT3 Picture Thread
