Cf 4.0 plenum and cup airbox insert
#64
Do we have any pricing yet? I'd be curious to see what this would do if anything on a 3.6 with just headers, exhaust , cf intake manifold/ dual intake setup and tune
#65
Thanks - I was surprised to see the numbers where they are without a tune...
Pricing is at sellers discretion so to speak - you can easily contact him at his website Autosearacing dot com
#68
Impressive, bigger pistons, engine needs to breathe. Nice. Look forward to the tune results. Then the cams results. :-)
I've seen some of the BBI work on various builds (they always have engines getting punched out there) and the headwork they do is impressive.
#71
PJS, those prelim (pre-tune) numbers are as nice as your new double snorkel CUP intake! You are sick, don't believe cams will afford you too much traction to slow you on your slippery slope.
#74
The reason im asking is i have a cup airbox and appropriate deck lid in route, and while Im not expecting significant gains, esp since im a 3.6 right now, im trying to determine does it make sense to buy the cf inner piece (waiting to hear back from autosea) to run the dual cone, or just stick a panel filter in.
#75
Well panel filter has a single air inlet and dual cone has 2 air inlets
If your decklid is "optimized" for the dual cone I am guessing you are able to get more air in
#laymansunderstanding
