Having my 4.1L GT3 custom tuned
I am having my 4.1L GT3RS custom tuned after seeing a AFR of 13.8 (peak). As most of you know 13.8 is quite lean. I'll let you know the results.
Yes, this is not a duty cycle issue. You simply need a tune.
I will also state that with knock sensors, you'll notice huge power loss due to pulling timing if there is a serious tuning issue, before any internal damage.
Jamie - I have a AFR peak of 13.8 so I'm pretty paranoid. If I get a better curve then it'll be a bonus right?
Serge - As I said to Jamie my AFR is at 13.8 which is lean so let's see how it goes.
Anton - Thanks for the best wishes. You have the best taste in terms of garage here. Just your 7RS 4.0 and MP412C makes me salivate.
13.8 is a little on the lean side for safety.
Couple things, where was the AFR measured (exhaust tips, with or without cats etc...) and how was it measured?
Do you have a plot vs RPM?
Ideal safe for most NA cars is 12.5 or so, although NA Porsches seem to run in the low 13's...
I'll get you a proper graph in a few days when it's done.
Cheers and thanks for looking.
