GT3 to CUP
+1 Peter. Thank you for the insight. I have considered the same thing. Thought of a leap from Interseries to a 6 Cup. This is really helpful info to consider.
GT3 player par excellence
pete, great post.
it appears that the older one gets, the slower one learns ;-)
Great post! I had a similar experience.
Couple tips after spending the last few years in various Cups:
* if you can drive correctly without the blipper, take it out. your gearbox will last longer. (but if you're faster w/ the blipper leave it in!
* You can buy the same Yokohama slicks that're used in IMSA GT3 Challenge and ALMS GTC. If you're keeping your car mostly stock, I'd run those so you can compare lap times to the GT3 Challenge races if you ever go to those tracks. The tires have pretty good life too if you're going to run them through multiple heat cycles (compared to Michelins).
* i'm not sure which pads you're using, but you might want to look into some of the endurance compounds if you're not going to be changing them frequently (for max performance) compared to the stock Pagid greens (sprint compound).
* Personally, I like using a helmet blower in the car more than a cool suit. Obviously, you get weight savings but it's also less stuff to worry about at the track. If you have a helmet with a forced air option I'd give it a try.
Have fun!
-mike
Have fun!
-mike
Have fun!
-mike
Have fun!
-mike
I should try running without the blipper now that I'm more familiar with the gearbox and brakes...
Thanks Peter for a great write-up. I've been thinking about a Cup for years, and your comments help cement the idea as a good one...
Hope to meet you at Miller this summer.
-Blake
-Blake
Talking with guys who know more then me about the mechanicals of the car, blipper equipped gear boxes seem to do a maximum of 12-15 hours before failure where-as non-blipper cars can go much longer (if driven correctly).
That's my 2 cents anyway, take it for what it's worth. :-)
-mike
#4 Brakes. I found the completely manual brakes surprisingly nice. I have locked up a couple of times but no serious flat spots yet thankfully. The bias is setup nicely and the feel is incredible. There is a far better connection between the driver and the brakes, I now have trouble going back to the regular mushy ABS brakes. I've considered adding the motorsports ABS to the car, it's about $6k so not too bad, so far no need though plus it's not allowed for PCA etc. Pads and rotors costs are similar to the later street cars..
Peter
Great post, thanks--you're my inspiration.
