And it begins.... 4.2L
#61
Thanks! Hopefully see you out at the ridge?
#63
Waiting for parts to come in, tested some ideas for cams that will work out! Also working on a CF plenum to open up the intake side and keep the plenum flaps. Getting quotes on the headers and exhaust as well... Things are moving, just not a lot of pictures lately!
#64
Jamie it all comes together but there's always anxiety but trust the individuals you've chosen. Just keep the build pics coming. All others and myself love to see it come together.
I'll say again, not sure that a CF intake plenum is a good "bang 4 the buck".
All the best with the build.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Ranger
Ranger
#65
Hey Ranger,
Thanks, the intake plenum should come out a little less than the factory 4.0 parts and the difference between the 3.6 and 4.0L plenums are definitely worth taking a look at...
#71
Question for you Serge, did you use the 4.0L fuel injectors? I know the factory bore is 102.7 and ours are 105. The wider spray pattern should help with hot spots, but did you do it with yours?
#72
Picture Update
To complement the 4.0RS Plenum we needed to open up the lower manifolds
see the difference!
![](http://farm8.staticflickr.com/7288/8737510170_964debf37b.jpg)
Valve Job...
![](http://farm8.staticflickr.com/7281/8736388941_8501d624bc_z.jpg)
Machining for the new cylinders
![](http://farm8.staticflickr.com/7281/8736386645_6304d2cf53_z.jpg)
![](http://farm8.staticflickr.com/7282/8736388711_1ee1a93fea_z.jpg)
Case Machining
Cams are finishing up, machining all done, waiting on the crank and rods to arrive to put her together!
see the difference!
Valve Job...
Case Machining
