997 GT2/GT3 Forum 2005-2012
Monoballs-- which are most effective?
Old 06-27-2012, 11:22 PM
  #46
Nizer
Nizer's Avatar
Received 1,856 Likes on 962 Posts
Originally Posted by Izzone
Giesha is mono everywhere, I threw the entire tarrett catalog at her
Car takes a set a bit quicker
Tire wear is much better
Ditto
Old 06-27-2012, 11:25 PM
  #47
Nizer
Nizer's Avatar
Originally Posted by savyboy
"Compared with conventional rubberbonded metal mounts, ball-joint suspension mounts permit more precise wheel control and more sensitive damper response. This enables more direct steering behaviour and enhanced performance potential. On the 911 GT3 RS, several suspension mounts on the front and rear axles were already realised as ball joints. To further enhance performance, the new 911 GT3 RS 4.0 features additional ball joint-type mounts on the multi-link rear axle. These are located on the inside of the lower wishbone and on the inside of the tie rod. The highest forces occur at these locations during cornering and these forces can now be transmitted directly to the vehicle without elastic deformation. This significantly improves the feeling for the driver at the rear axle. A further ball joint is located between the wheel carrier and spring"
Pete: Can elaborate on the last sentence in bold? Any pictures or diagrams of this item? Thanks.
Old 06-28-2012, 07:14 AM
  #48
997gt3north
997gt3north's Avatar
That almost sounds, but not quite, like it could be implying a rear monoball shock mount since they mentioned the spring. If so, that would be a part that Tarett and others sell. I have the Tarett part - you can see it on his site or in the picture right here
Old 06-28-2012, 08:01 AM
  #49
Nizer
Nizer's Avatar
Yes, but that's the upper shock mount and Savy's seemed to be referencing the lower shock mount??
"3. Rear lower shock mount solid mount.
#3 requires you to change out the carrier$. How committed are you?"
But I could be confusing separate parts of his post, hence the request for clarification.
Old 06-28-2012, 08:55 AM
  #50
Izzone
Izzone's Avatar
Originally Posted by mdrums
...and all are TSB updates so car remain stock, right?
Tarrett front monoball end
Tarrett rear monoball end
Tarrett front thrust arm bushing (adjustable)
Tarrett rear thrust arm bushing (adjustable)
Tarrett rear upper controls arm links
Tarrett rear toe arms
Tarrett locking plate kit
Tarrett front tie rod
Tarrett front drop links
Tarrett rear drop links
All TSB updates
Old 06-28-2012, 09:33 AM
  #51
997gt3north
is this it?
Old 06-28-2012, 10:30 AM
  #52
savyboy
savyboy's Avatar
is this it?
Yes, that is it. Must change carrier to 2RS/4.0 PN to get a solid joint here. It makes a big difference for such a "small" joint. $$ and effort to make this one happen. Carrier is not so costly, but it is a lot of work. We will see who the seriously afflicted are when we get some pics of this being changed out!
Old 06-28-2012, 10:41 AM
  #53
997gt3north
- can't the existing one just get pushed out and have Ira at Tarett fab one up?
- i can ping him and see if it is doable
- he made me the rear spring mount pretty quickly
Old 06-28-2012, 10:53 AM
  #54
savyboy
savyboy's Avatar
It would be some cost savings if he could do that. Post up his response? As I recall the OE 2RS/4.0 carriers are surprisingly low-cost. $400 each I think.
Old 06-28-2012, 11:34 AM
  #55
Serge944
Serge944's Avatar
Originally Posted by Mvez
+ these. Then forget about it. There's a reason the 4.0 gets them from the factory. I'm a believer after using rear LCA monoballs. Tarret makes a great piece, super easy to install.
http://www.tarett.com/items/996-997-...996-detail.htm
It's a very slippery slope...
Yes, I had those on my 996 4 liter, along with other Tarett bits. IMO, they are the best in the biz.
Old 06-28-2012, 01:08 PM
  #56
TTurbine
TTurbine's Avatar
Better grab them fast , before Porsche reads this thread and bumps the price to 3,000k
Old 06-28-2012, 05:13 PM
  #57
Larry Cable
Larry Cable's Avatar
Received 3,601 Likes on 2,341 Posts
I would put the monoballs on the rear LCA, add the toe-links and stop there. To me, molesting the front gains primarily harshness. Think about it, there is no weight up there except for braking. The rear does everything. '11RS is so good out of the box. Unless you are running Hoosiers, adding a bunch of camber creates other problems- dartiness and tail wag under braking.
+1
Old 01-08-2013, 08:37 PM
  #58
John Chan
John Chan's Avatar
How is this rubber joint affect alignment and handling? Not a pivot point? If this rubber joint flex and change alignment, then the upper suspension mount rubber bushing will be doing the same thing too. So I do not understand how this rubber bushing affect handeling?
Old 01-31-2014, 01:50 AM
  #59
Protocav
Protocav's Avatar
Drug this thread up from the dead...
There has been a bunch of discussion on the 4.0 suspension on this thread. Can anyone tell me exactly how the 4.0 differs from the "regular" GT3's?
Sounds like monoball contol arm pivots and rod end toe links, but does the 4.0 still have rubber caster pucks and rubber in the dog bones, etc...
Thanks!
Old 01-31-2014, 02:48 AM
  #60
mooty
GT3 player par excellence
mooty's Avatar
Received 5,659 Likes on 2,326 Posts
toe link is monoball on chassis side.
there are tons of differnece. it's not listed by porsche marketing material
we have RS4.0 and 3.8 parked side by side. we think the tranny case is different. but i am not sure.
Quick Reply: Monoballs-- which are most effective?
