997 GT2/GT3 Forum 2005-2012
Monoballs-- which are most effective?
Old 05-19-2012, 12:18 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,640 Likes on 762 Posts
LSD if you don't have one yet and rehear.
Old 05-19-2012, 12:33 AM
tcsracing1
tcsracing1's Avatar
i have everything under my RS that you can buy....
for track fun, all one really needs is rear toe links as the stock ones knock out of alignment way too fast on the track...
you could also benefit front adjustable sway bar links to adjust the ride height.
everything else is icing on the cake...
My car typically takes two days to align, corner balance and bump steer... but man is it ever nice!
Old 05-19-2012, 12:45 AM
silverboy
silverboy's Avatar
Two days to align? Wow. I am having second thought on mine then.
Old 05-19-2012, 01:15 AM
tcsracing1
tcsracing1's Avatar
the big work ( approx a day) is setting the bump steer correctly using RSR style Tension/Compression Links...... buying them is the cheap part, making them work is the expensive part.... (labour)
The other killer is that not all CUP cars are allowed to run them based on the series they run in, thus only certain CUP car shops/teams use them and understand how to set them up to work properly with experience and data....
Old 05-19-2012, 01:22 AM
drl
drl's Avatar
What are these? The pieces that link to the sway bars? What is the link connected to sway bar in front?
Old 05-19-2012, 02:09 AM
Doublej
Doublej's Avatar
And, you can see the install on Tom's RS here:
https://rennlist.com/forums/997-gt2-...-part-1-a.html
Old 05-19-2012, 04:16 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,660 Likes on 2,327 Posts
^ that is the very last piece you need to mod.
but imo, you only need to mod when you spend more time than izzon or tracker on track. otherwise, don't bother.
Old 05-19-2012, 10:32 AM
BBMGT3
BBMGT3's Avatar
Interesting thread. I've already done the toe links and the dog bones. Am thinking of putting in a 3-way adjustable in my .1gt3. But wanted to make sure I combine it with the right solid stuff. Front top mounts for added camber? (I max out at 2.2-2.3).
Old 05-19-2012, 03:17 PM
ir_fuel
ir_fuel's Avatar
Turn around your top mounts. If you max out at 2.2-2.3 they haven't been turned so you can get more by doing that.
Old 05-19-2012, 04:04 PM
M3EvoBR
M3EvoBR's Avatar
Don't turn otherwise you will compromise caster. Buy the proper lower control arms with it's inner monoball joints.
Old 05-19-2012, 05:20 PM
TRAKCAR
TRAKCAR's Avatar
I don't have my struts.... Car handles fine.
Old 05-20-2012, 02:15 AM
BBMGT3
BBMGT3's Avatar
LCA or thrust arms?
Example?
Old 05-20-2012, 03:17 AM
Nick Wong
Nick Wong's Avatar
I wonder if anyone actually listens when I say the same thing. Probably not.
Old 05-20-2012, 03:59 AM
BBMGT3
BBMGT3's Avatar
Wasn't able to get a hold of a race/suspension engineer.
Old 05-20-2012, 08:21 AM
ir_fuel
ir_fuel's Avatar
Turning works perfectly fine. Had my car alignment done by Manthey Racing last year and first thing they asked was if I turned the top mounts already. If not they would have to do it.
Quick Reply: Monoballs-- which are most effective?
