48hoursofsebring.com 2012
#721
Eddie boy, your car has monoballs everywhere, I put monoballs on my 996 GT3 and performance got massively better, I dropped over 1 second at Pocono North course with full monoballs.
2:19.99 is not 2:19, 2:19.00 is 2:19.
2.18:99 is 2:19
2:19.99 is 2:20
Plus, the iPhone stuff with a 16 meters accuracy, is far from a trusted data source.
With your cheater parts, and a working LSD, you could also run 2:18s on RA1. Reter's car doesn't have as many cheat parts in the suspension (where it matters a lot), but he has some nice Aero bits.
2.18:99 is 2:19
2:19.99 is 2:20
The only parts I have are:
Camber arms (dog bones)
Toe link
Also Temperature wasn't ideal at the 48hs... just a few clean laps as you can see from the videos. The video don't lie. Time it if you want.
Traqmate will be in shortly. LSD is not working at 8300 miles anymore.
#727
Im slow into 10.....my fault
Im slower in13.....my fault
It doesnt save a second braking into bishops
Sure at the limit the car is faster.....but it doe snot bolt on minus two seconds....YMMV
#728
2.18:99 is 2:19
2:19.99 is 2:20
2.18:99 is 2:19
2:19.99 is 2:20
Toe link
Toe link
And CUL lip and side thingies
And probably custom tune
No LSD but 8000 miles only a few hunderd track miles = working lesser OEM LSD..
You will get slower with less then prime RA1's and wearing LSD, watch it happen.
#730
I ran 2:18xx or as you would say, not 2:18 but 2:19??!!
And Gurney flap
And Gurney flap
#735
The above are better mods than the regearing which was only good in traffic but not faster on clear laps where momentum takes over. I worked really hard to drive that car whoof! Now things are a bit easier but soon I will need to upgrade LSD as I feel it going.
