Gt3 owners with gt2 rear sway bar
#137
#140
Yes on the GT3 they are.
On 997.2 GT3, it got the upgraded thicker (25.5mm) rear bar from the GT2. This was to help dial out understeer.
Not sure if the front bar changed. But in general if your buying bars then buy the latest ones which are the 2010 onwards 997.2 GT3 bars.
You need:-
997.343.701.94 is the front 997.2 2010 GT3 bar
997.343.792.00 are the front D-bar bushes for the front bar.
997.333.701.96 is the rear 997.2 2010 GT3 bar (same as GT2 bar)
997.333.792.94 are the rear D-bar bushes for the rear bar.
You need:-
#143
you will need the appropriate brackets and you will need to lubricate the associated rubber bushings (perferably with a silicon lub)
#146
Make sure you have it full soft. My shop inadvertently set it at full stiff initially and the car was a handful. On full soft with GT3 front bar on one less than full stiff car was very neutral. I ran this se up on 2006 C2S and 2007 GT3.
#147
I run the front bar in the middle (1 stiffer than delivered)
I also have reduced the car's rake from the factory 25mm to 15mm and lowered the car
- factory is 108/133, i'm at 90/105
I had a top racer mention to me about lowering the rear to increase grip - there is also an extremely fast mancation member who advises the same
Also, what is your rear camber?
#149
+1. With this bar, a narrow body will have a touch more oversteer than a RS. DD95 could add a hair more rear camber.
#150
The bar is setup properly. Everything is where it should be.
Camber is 3.5/2.5 respectively on hoosiers. Moving to NT01 as soon as last set of hoosiers is done. Will realign at that time.
The car is very snappy.
