Gt3 owners with gt2 rear sway bar
Wanted to see what settings you are running your away bars at. I'm running stock suspension with stock front bar and gt2 rear bar.
I'd avoid full stiff on the rear ... I ran it with "middle" when I had my .1 ... front was at factory default.
What does the GT2 bar buy you vs. the stock rear bar?
Larry, thanks.
You are correct - It is only $310 from Suncoast, including the bushings.
Can someone walk me through the rationale of this mod?
The .1 on full stiff is, well, stiff. Don't see why you would want it even stiffer. What does the gt2 bar do exactly?
Admin
full stiff on either bar is very stiff ... I personally found it to be challenging to drive my 996.2 on full stiff.
using the GT2 bar on the back in middle setting dials out more/enough of the understeer when compared to the bar fitted better than that bar, full stiff is probably too much and makes the rear end very dynamic...
YMMV
Admin
Understeer is when you hit the wall with the front of the car. ---GT3.1
Oversteer is when you hit the wall with the rear of the car. ---GT2
So we take the bar of the mighty but slightly over-powered GT2 and put it in the GT3.1
And now we have a more balanced car and no wall.
JGEMDOC (06-13-2024)
