Center lock will be changed by dealers soon
#91
GT2 anti-roll bar for a Mk.2?
I know it did wonders to the Mk.1 cars but why on the Mk.2? The car seems fine as is.
Maybe they are so slow to react that the bulletin has been issued for the new cars and they don't know any better.
#92
Usually all new TIs are published in the PIWIS in English within hours or days. Since I don't have a reason not to believe you, maybe the German version was published first, or perhaps Porsche has delayed updating this TI in their WW network.
Will keep checking for it. In the meantime if you have the TI number, please post it.
#95
OK guys just got back from the dealer. They removed the 4 centerlock bolts and checked the part numbers. Mine need to be replaced since they are the old one. Moreover they also checked all the wheelhubs and apparently there is damage to one of the rear hubs too (I believe the thread is damaged). This is something they also are required to check and they will replace this hub also under warranty.
From what I understood the problem is that the "old" centerlock bolt isn't made for supporting 600Nm.
The number he gave me for the recall ("the internal number" he called it) is WB10.
#98
Something else:
this weekend we have the Porsche Days on the Francorchamps racetrack. A friend of mine with his MK2 RS wanted to drive there so he contacted the dealership. Apparently they are refusing track access to any mk2 cars ( centerlock ) that didn't have the recall work done
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#100
HERE IS RESPONSE:
Ok I looked for any information other then the one I already found for you in regards to center lock wheels and I didn’t find anything.
I agree that there is different part numbers for the center lock hubs but they don’t supercede to one another, as far as I can tell.
If there is any damager to his hubs caused by the part itself and not subsequent installation it would be covered under warranty.
I looked but didn’t find anything listed under a wb10 recall or campaign.
ADDITIONALLY
Francorchamps is not here in the US. If for some reason either the club running that specific event or the track officials are restricting access for specific cars due to “recall” work it might be a decision on their part in order to limit potential liability as much as any inherent danger in using the cars without having the work done. Tough to say what the situation is with that…
ADDITIONALLY
#101
If what your telling us is correct ir-fuel, then the Porsche engineers are a bunch of dumbasses (an "r" word actually sprung to mind but i didn't want to be politically incorrect). This makes Porsche no better than Ferrari and their superglued wheel liners... Bad enough they fked up the grease and torque requirements initially but what moron rolls out a fix of just torquing them up without doing stress testing on components to ensure the fix is good? Also, if ur going to introduce new technology, why not test it properly on their prototypes? All the test mules were 5 studs....
They'd better be happy to dip into their pockets to replace my second track set too as they had no right to sell me a dodgey second set in the first place.... If questionable, stock should have been quarantined pending proper testing...
#102
An interesting anecdote to this CL mess, in the 80's, Porsche's racing program had issues with center bolts on the fabled 956. The factory cars were unaffected, but the privateers repeatedly lost wheels during races. The fix/edict from Norbert Singer, use more torque.
#103
#104
Update- no recall as of yet if at all
here is what I got:
Bobby,
I did a little more research and here’s what I found.
There are 2 technical bulletins in regards to the center lock wheels.
They are as follows;
Ti4405, special applications for driving on race track, which you have
wm440519, removing and installing wheels with central bolt.
Basically it outlines the correct procedure for removing and installing the center lock bolt. I’ve printed a copy that I have here for you and can fax it to you if you’d like to see it right away.
Again, with a specific VIN number I can run it and see anything and all things that would apply to it such as TSB, service updates, campaigns or recalls.
Hope this helps,
jimi
here is what I got:
Bobby,
Hope this helps,
jimi
