Rennline solid engine mount review
#46
Received 1,864 Likes
I've been through their shop - impressive facility. They do a lot of specialized fabrication work for aerospace industry. Great guys too. I trust they'll get the thing sorted quickly.
#47
Cfjan...my 2007 7GT3 has the solid cup car engine mount illustrated in this thread plus the suspension is completely solid. No issues with the electronics at all and so far not a lot of other things being vibrated loose.
#49
I do it all the time in very tight corners. I ran at Buttonwillow last weekend which has 2 tight turns, one with a declining radius. In order to carry more speed into a tight corner I turn-in while still in 3rd and allow the car to coast a second in the taller gear. I then downshift after corner entry and start getting back on the throttle for track-out. I wouldn't let out a clutch with a high rev load mid corner, but as described above you're in a low RPM stage and feel little effect if any from the downshift. The net result is a much faster corner entry than downshifting to 2nd....
#50
Update:
Spoke with folks at Rennline and they made the necessary modification on the solid engine mount to fit our GT3/RS. I should have the first set in about a week or two. Stay tune
#52
Admin
Mike do weigh them pls I wanna see how they compare to the 993RS semi solid ones.
#54
911SLOW, I also have the 993RS semisolid ones on a 997tt that has the full cup/rs susp components. Do you have experienced vibration and/or stiffness issues with those that you are hoping to solve with the solid ones?
#55
Admin
The car feels as one with them and I can’t really feel anymore the rear mass moving independently and with a delay compared with the rest of the car.
No apparent added vibration from the semi solids. And they are lighter than oem about 2lbs.
I do consider them a maintenance item and will change them when rubber on them starts to let go. Like the transmission mounts I recently changed.
I was very surprised that Mike reported no vibration with them, it goes against logic since there is metal to metal contact and zero isolation but I take his word for it and besides vibration feeling is quite subjective.
Just want to see how much lighter these are. Maybe I give them a try down the road.
#56
Thanks, I guess I ll check the rubber in mine. I just wondering if the mounts are responsible for the hashness in the back when I hit a pothole.. Or it could be any (or all) of the dog bones, toe links, sway bar, droplinks, cup lower control arms, dymags..! Am curious what P installed on the GT2RS from the above list since ride is apparently pretty decent for the handling characteristics.
#57
inquiring minds want to know
I have a set of new wevo ss mounts in a box awaiting completion of this thread before I get them installed... thinking I might just go straight to solid mounts...
#60
Basic Sponsor
These are on the shelves and shipping now
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
