Sport Button Exhaust Issue??
Hi Guys,
I went for a drive tonight and for the first 30 minutes the car sounded awesome with the Sport Button on.
Then I was stopped at a set of lights on a steep inclibe front of the car pointing down when the exhaust started making a strange vibrating sound.
When I took off the it sounded as though one or both of the valves in the exhaust were stuck closed.
No matter if I switched it on or off, the car still made this horrible noise and it also seemed under powered.
I switched the car of several times without any luck. So I headed back home and after about 25 minutes the which was just before I got home the exhaust went back to normal.
Does anyone know WTF that was all about??
Thanks for that.
So do you know what caused the problem?
Did they unplug them for good to fix the problem or did you do it?
Yes that happens and car sounds like a sick cow when it does !! Irritating. Seems to occur prevalently when the chassis of car is stressed somewhat ie , backing out of your drive way etc.
See attached pictures (with thanks to Drake) note that you must prss the wire clip in order to detach plug:
