Catastrophic Coolant Hose Coupling Failure Registry
MGT3 (09-16-2020)
#707
#708
#710
Had mine done preemptively as it was high on my list when i bought the car. 997.2 gt3 47k miles. Tech said he pulled three of them out with his fingers with ease. Yikes! Definitely happy i had mine done. Bought the BBi kit, along with the Sharkwerks elbows and had them welded in along with a ton of other items while it was out. If anyone needs a place in Western NY to have theirs done, Eksten Autoworks is the place to go.
MGT3 (10-16-2020)
#711
Just a reminder to get these done if you are going to the track. This past weekend I instructed at our local club track and a novice student (first time to any track) in his 997.1 gt3 lost a coolant line. I was in a students car and he was the first through the mess afterwards. Coolant was dumped in the braking zone of a fast corner. Student went to brake and obviously nothing happened. We went right off, thankfully he was not going terribly fast. Three other cars behind us went off, one of which was a GTI which got airborne and ended up finding a tire wall which caused a fair amount of damage to the GTI. The GT3 owner was completely oblivious to the coolant line fitting issue. Scary stuff.
The following 5 users liked this post by lcrain:
GM.RS (11-17-2020),
MGT3 (11-16-2020),
Rioja del 73 (03-09-2021),
s65e90 (11-16-2020),
yohoba (01-06-2021)
#714
For many of us, we are getting ready to store our GT3's for winter. This is a great time to think about doing coolant lines if you're planning on going to the track next year or even if you're not and just want to give yourself some peace of mind on the street from being stranded, or worse spinning out or causing someone else to behind you. While we don't know yet if it was a 996/997 that caused this accident, I think it's safe to assume it was, which is unfortunate. Likely could have been prevented with pinning/welding.
https://www.roadandtrack.com/news/a3...eup-kills-one/
zshecht7792 (10-06-2021)
#715
Thank-you for this post and reminder!
The glued coolant bung ISSUE with the Metzger is very real.
The engine is as tough as an anvil except for this very atypical (and unforgivable IMO) weakness.
Having these welded or pinned should be MANDATORY for all track events on 996/997 GT3s.
#716
Agreed. I will not go to a track until mine are done. This new story further solidifies that. What a tragedy at the Nürburgring.
#717
#718
The following 2 users liked this post by Bxstr:
Robocop305 (10-06-2021),
#719
2009 Cayman Base PDK
102K miles
Track Day at Portland IR
COV (Cross over Valve) to PDK oil/water heat exchanger exploded - towed car home
Repair - Option 1 replace plastic COV with OEM plastic COV; Option two - bypass COV with straight aluminum tube and seal off vacuum line to COV (equivalent to valve always open)
I did Option 2 - does anyone know why there is a COV in this water circuit?
102K miles
#720
I have a really stupid question: Is there a way of knowing if your lines are pinned by simply looking into the engine bay?
I bought my .2RS from John Wright at PNH 2 years ago with 1900 miles on it. I now have 3930 miles on it and I am somewhat worried about the hose coupling failure problem. I do not track the car, just use it for recreational driving on regular roads.
Thanks,
Raghu
Thanks,
Raghu
