Race-Keeper data system
#61
#62
#63
Nice comparison software for the VBOX-- being able to see the vehicle position on the line (not just the distance point around the track) is pretty compelling. I wonder what kind of GPS sampling resolution they achieve to be able to position the car location within 10cm or whatever -- I see they advertise a 100Hz unit (at $6K+) but I wonder if there's a differential beacon or something to improve the fix?
#64
Former Vendor
Those videos remind me of some computer software "training" videos (say a video editing application) that spends time showing how "to open a file, left-click the 'file' menu and move the mouse so that the cursor, the small, white arrow on the computer display, points at the word 'open' in the list of words that appears below the word 'File' in the File menu.) Truly bizarre. And the "calibrate" video shows no means of calibration, it shows how to change the orientation of the accelerometer according to the installed orientation of the RK box. Useful knowledge, but it's nothing to do with a calibration or range and scale adjustment. Second, the "zeroing" or "center" of the accelerometer is fun, too, but again it's not calibration, it's just a reset of the zero -- this doesn't help with the problem of the "bubble" continuously pinning FSD. At least the data graph does rescale. I wonder if there's a way to get actual raw data out into a spreadsheet?
About exporting the raw data, I have requested this some time ago (look in the Wish List section of the discussion forums.
#65
Former Vendor
There is actually a detailed description of focusing the cameras on the website. Navigate to the 'Support' page, then 'Discussion forums' and then the 'Race-Keeper Discussion' forum. There is a description of how to focus the cameras. I like using a cheap DVD player that has a 'video in' port so I can actually see what the cameras are seeing, real time. Switch the system to single stream and connect the camera that you are focusing to video port #1. If you have a good 12v power supply outside of the car, you can even do this indoors.
#66
Cheers,
#67
Former Vendor
I am not saying that this in not useful, or cool. It all depends on how much time and money you are willing to put into data/video acquisition systems.
If you need to increase accuracy, you can get a DPGS unit that transmitts correction data to the GPS receiver.
The sampling rate 10Hz or 100hz just defines how much data you are collecting. A higher sampling rate will generate a lot more data in the same amount of time.
It's like the units that advertise that they have two GPS receivers and can plot the angle that the car is moving. But very simply, if you have two receiving antena's 3 meters apart with a 5 meter accuracy, they could tell you that the back of the car was in front of the front of the car (hopefully this is not the case!!!!! cause then you would be traveling backwards). This may be very simplistic, so correct me if I am wrong.
#68
Former Vendor
I'll check and see what the deflection scale is for the acceleromter graphics (not the graphs).
#69
....If they don't have a track map for the track you are at, you will have to create one using the procedure they describe which involves driving around the course with the antena mounted in a specific place on your car, and driving around once on the left side and once on the right side, again subject to the +-5m accuracy.....
alternately is there a map for Lime rock, Watkins Glen(long), Monticello(full)?
#70
Former Vendor
Their website is www.racelogic.co.uk or their US outlet - www.vboxusa.com. Although I could not see anything about downloading track maps from their site.
#71
Bill: Sorry, I thought I responded to you, but I may not have hit the send key.
#73
Former Vendor
When I checked, it looked life full deflection was about .9 g's.
#74
That's way too low. Not sure how the programmers came up with that number unless they tested it on a Toyota Tercel and assumed sports cars would be a little higher. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Like I said earlier, if they can set the default to be 1.5g for now and add a GUI update later on so the user can change it, it would make the accelerometer useful. Right now there is no point in using it when it'll max out so easily.
Cheers,
Cheers,
#75
Former Vendor
Cheers,
Cheers,
BTW, there are only two months more to register for their New Year's Eve giveaway - a SE system. This is open to everyone! Even if you have already purchased a system! Present users will have their choice of a second system, or a refund of the system price.
