997 GT2/GT3 Forum 2005-2012
Porsche and it's 15% rule
Old 11-16-2007, 10:28 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,743 Likes on 1,084 Posts
Originally Posted by 997gt3north
Cars don't live on a dyno, they must move their mass from point A to point B from lets say speed 0 to 100mph - it clearly requires more energy to move 3400#s than 3200#s - if Porsche wants to interpret this as efficiency (stretch) than the GT2 is more efficient as it has to accelerate less mass
Yes, I see your point and agree with you on the level that you are arguing. In fact, one great way to reduce your MPG is to drop weight. I think this might be one good reason why the new 'Vette has such great highway mileage, even though it can produce 500HP.
I think Porsche's argument might make sense if they are assuming that the 3200# GT2 will go from 0 to 100 mph quicker than the 3500# Turbo, thereby reducing the time the 530HP engine must produce work by consuming massive quantities of air and fuel. So with less time to move less weight, I can see a potential gain in MPG.
Old 11-16-2007, 11:05 PM
allegretto
allegretto's Avatar
Originally Posted by OldGuy
As an engineer I dont know if I believe thier "genuine revolution" claim.
The air going into the turbo still gets compressed and PV=nrT says that as the
gas gets compress its temperature is still going up. Then it gets
compressed in the cylinder once again so that slight expansion
in the intake would be of minimal importance and certainly not
a genuine revolution.
I see you have not been properly indoctrinated...
Where are you papers?
You have relatives near Stuttgart, no?
Old 11-16-2007, 11:09 PM
allegretto
allegretto's Avatar
Actually in the Z 06 fifth and sixth are overdrives, this helps a lot! But mass doesn't hurt.
In truth it is kind of a comical claim that at full-throttle a car gets X% better milage. Like that's a concern at WOT?
So let's see...maybe one gets 4 MPG and the other 4.6MPG? Not the stuff of "Revolutions" exactly.
Old 11-16-2007, 11:19 PM
jimhuber
jimhuber's Avatar
efficiency how?
Well, like not having a 4WD system.
Jim Huber
Old 11-16-2007, 11:40 PM
Mike Murphy
Yes, I agree, it is fairly comical
Mike Murphy
Jim Huber
I would say that this has to be "it."
Old 11-16-2007, 11:46 PM
Mike Murphy
Well, the idea of the intercooler is to cool the hot air caused by the compression of the turbo. So a more efficient intercooler should cool the air more, causing it to become more dense, which means that you have to add more fuel to the incoming intake charge, which produces more power.
So a more efficient turbo/intercooler would actually cause fuel efficiency to go down.
Old 11-16-2007, 11:57 PM
OldGuy
OldGuy's Avatar
Murphy I agree with the intercooler but the Intercooler has alot of surface area and the area has to
be caculated to get the proper effect. I dont see how enlarging the intake area in a very small
area compared to an intercooler will do anything, and really its no genuine revolution.
It all depends on the the speed of the car and the mass of the air in the intake. There is a limited
amount of space in the intake area as opposed to increasing the surface area of the intercooler.
the air flowing over the intercooler fins is a lot more complicated that a simple compression of
a gas.
A nice marketing gimick.
Old 11-17-2007, 01:20 AM
NSXTC
NSXTC's Avatar
Yep, Porsche is good at marketing gimick...Perfect example...the side vents on the GT3 rear bumper...brochure says it draws out hot air from the engine bay.
Well guess what. It does nada. Proof? ->https://rennlist.com/forums/997-gt2-gt3-forum/385831-gt3-rear-bumper-apron-porn.html
Old 11-17-2007, 03:44 AM
pole position
pole position's Avatar
The Greenies have a very strong influence in Germany. Most of the new fuel savings, noise etc comes from their side. It is easier for Porsche to please those thinly disguised communists then to fight them.
Old 11-17-2007, 06:08 AM
Yargk
Yargk's Avatar
I think we are beating this to death when it's very simple. The car uses 15% less fuel under full load. The only measurement under full load that makes sense is liquid volume per time. You floor it for 10 sec with it stuck at 5000 rpm (use a dyno with brake) and measure how much fuel is used. It uses less fuel, but makes more power because the intake air is cooler. A basic result of thermodynamics says that the efficiency of a heat engine is limited by the difference in your high and low temperatures. The low corresponds to intake air temp and the high corresponds to the temp after combustion. I feel there might be additional, less basic (to me), reasons why cooler intake air is more efficient, but I'm not an automotive engineer.
Porsche is very intelligent when it comes to these things. Any remarks that this car is part of the problem are countered by the good gas mileage found on the European cycle and any further criticism that this car will be driven hard (not like European cycle) is countered by the fact that even when driven hard the car uses less fuel, which is actually quite an achievement, not just marketing bs. After reading the AMS supertest, this thing hauls and handles and to think it's cleaner and more efficient with a crazy 530 hp, WOW.
Old 11-17-2007, 06:31 AM
Pingo
Pingo's Avatar
According to Porsche, the expansion intake manifold uses the principle of oscillating air in the intake manifold during the cooler expansion phase, keeping the temperature of the fuel/air mixture lower than that of the 911 Turbo.
Old 11-17-2007, 08:54 AM
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 2,300 Likes on 615 Posts
15% really isn't that much more efficient because like someone said earlier you're only getting 4-6mpg at full throttle anyway...but most of the improvements on mpg have to do with better either direct or indirect ECU stuff which, being computer hardware and software can evolve at an extremely high rate.
Old 11-17-2007, 09:25 AM
eclou
eclou's Avatar
Received 1,234 Likes on 604 Posts
we had a long discussion on the expansion intake here
Interestingly enough, some Rennteam members have run a RUF 550 997TT vs a new GT2 0-300kph, and the RUF was faster by a hair (still using stock TT non-expansion intake and stock TT VTG turbos)
Old 11-17-2007, 10:17 AM
C.J. Ichiban
Platinum Dealership
yeah but how many mpg? hahaha
Quick Reply: Porsche and it's 15% rule
