997 GT2/GT3 Forum 2005-2012
Porsche and it's 15% rule
Old 11-16-2007, 04:07 PM
Mike Murphy
Mike Murphy's Avatar
Received 1,743 Likes on 1,084 Posts
Default Porsche and it's 15% rule
Every time Porsche comes out with a new car, they claim 15% better this and 15% better that.
In this latest example, "Car & Driver" magazine tests the new GT2, which "...curns out 530 horsepower at 6500 RPM..." and "Despite the power hike, Porsche claims fuel consumption at full throttle is improved by 15 percent compared with the Turbo."
Now how can you save 15% fuel economy at full throttle while making 530 horsepower versus the lower horsepower 911 Turbo engine? If the compression ratio had changed, I could understand it, but it appears this GT2 engine makes power with larger turbos and a new intake manifold.
Old 11-16-2007, 04:15 PM
Crazy Canuck
Crazy Canuck's Avatar
efficiency
RR
RR's Avatar
First at full throttle the GT2 isn't making 530HP.
Also the GT2 weighs less than the Turbo and also only has 2 wheel drive. 4 wheel drive is a gas guzzler.
Old 11-16-2007, 04:18 PM
Mike Murphy
Originally Posted by Crazy Canuck
efficiency
efficiency how?
Old 11-16-2007, 04:21 PM
Mike Murphy
I'm talking about the new GT2 - the one that isn't really out yet. Car & Driver is saying, "530 horsepower at 6500 rpm and 505 pound-feet of torque between 2500 and 4500 rpm."
I get what are saying about 4 wheel drive and 2 wheel drive - that would make sense if the horsepower numbers were the same 480 HP engines as found in the Turbo. But to make more HP with larger Turbos and intake means more air and more air means more fuel.
Old 11-16-2007, 04:22 PM
Mike Murphy
Oh, and I don't know how weight has anything to do with it at full throttle. Even if the car were 1,000 lbs heavier, it would still make the same 530 claimed HP would still consume the same amount of fuel at full throttle, wouldn't it?
Old 11-16-2007, 04:46 PM
997gt3north
997gt3north's Avatar
No
giving you are accelerating while at full throttle (unless you are going off a cliff, floating in space, are up on blocks with your wheels being stolen, etc) you are in the case of a GT2 accelerating less mass and also with less drive train loss with 2 wheels so you will not require as much energy to do so = more full efficient
i would think it is possible given the wt and additional drive train loss that their 15% statement at WOT is correct but who is oging to test this anyways
Old 11-16-2007, 04:58 PM
cosmo
cosmo's Avatar
outa the way!!! Whoosh!!
Old 11-16-2007, 05:10 PM
Mike Murphy
Originally Posted by 997gt3north
No
It must just be the 4-wheel-drive versus the 2-wheel drive, because from a physics standpoint, it would be impossible on the mass argument. For example, if you put both cars on a dyno, side-by-side at full throttle, the 530HP GT2 will burn more fuel than the 480HP Turbo will.
Old 11-16-2007, 05:27 PM
sbarton
sbarton's Avatar
Are you sure they meant 15% fuel effeciency at WOT? Who calculates mpg ratings at full throttle? Usually its just CITY/HWY, not CITY/HWY/WOT! LOL!
They only thing I can think of is that the new turbos/intercoolers are more effecient and create less heat. If they create less heat, then they would not have to run as rich.
-Scott
Old 11-16-2007, 05:31 PM
multi21
multi21's Avatar
Received 3,423 Likes on 2,033 Posts
In the latest Panorama Mag they quote 15% as well. The compression is different according to them and some other stuff. Read Panorama if you have it, it's pretty detailed.
Old 11-16-2007, 06:57 PM
Pingo
Pingo's Avatar
The GT2 is fitted (a first from Porsche) with a expansion-type intake manifold which they describes as a "genuine revolution". It keeps the fuel/air intake cooler which improve efficiency and reduces fuel consumption.
Old 11-16-2007, 10:00 PM
997gt3north
Cars don't live on a dyno, they must move their mass from point A to point B from lets say speed 0 to 100mph - it clearly requires more energy to move 3400#s than 3200#s - if Porsche wants to interpret this as efficiency (stretch) than the GT2 is more efficient as it has to accelerate less mass
Old 11-16-2007, 10:11 PM
Mussl Kar
Mussl Kar's Avatar
Gonna get 15% more buyers to get one, and they will.
Old 11-16-2007, 10:17 PM
OldGuy
OldGuy's Avatar
As an engineer I dont know if I believe thier "genuine revolution" claim.
The air going into the turbo still gets compressed and PV=nrT says that as the
gas gets compress its temperature is still going up. Then it gets
compressed in the cylinder once again so that slight expansion
in the intake would be of minimal importance and certainly not
a genuine revolution.
Quick Reply: Porsche and it's 15% rule
