997 GT2/GT3 Forum 2005-2012
AliExpress Head Unit install
Old 06-29-2024 | 12:50 AM
  #61
997GT's Avatar
997GT
Where does the MOST decoder connect to? I have SPP and there’s a distinct lack of bass when I left the fibre optic disconnected.
Old 06-29-2024 | 01:28 AM
  #62
Mr.TT's Avatar
Mr.TT
The fiber optic line goes into the decoder box. The decoder box has some wires that connect to the battery and ground (yellow and black) wires on the radio-side harness. There's also 2 RCA jacks that connect to the audio out jacks on the headunit. Then separately you have to connect the antenna wire (orange and black) from the HU harness to the wire that's in the image above which is the trigger signal for the ASK amp to turn on. If the amp doesn't turn on you won't get any sound through the door woofers which is where the bass is coming from.
997GT (06-29-2024)
Old 06-29-2024 | 11:09 PM
  #63
Full Boost's Avatar
Full Boost
Why do I feel so left out!
I'm thoroughly confused....
All i want is the .1 grey - with Bose. I want to use CarPlay and Waze. And charge the phone....
I tend to not take calls whilst driving.... but I do have an aftermarket mic in my car - so that might be useful??
A direct link would help me??
Old 07-01-2024 | 05:31 PM
  #64
jason95R's Avatar
jason95R
I'm thouroghly confused too. I have a .1 with the very basic CDR-24. No Bose. No NAV. No nothing. Can someone in the know post a link to the right one? Thanks
Old 07-02-2024 | 07:34 AM
  #65
Dervish's Avatar
Dervish
+1 same ^^^^^
Old 07-02-2024 | 12:29 PM
  #66
RAudi Driver's Avatar
RAudi Driver
Several things to decide on:
Camera: yes or no
RAM: get the larger size as 2g can stutter on maps if you're using other apps also.
ROM: I don't think it matters as we don't store much in our radios. What really need to be written to the radio besides the clock, users and radio stations.
Bose: if you have it, you'll need to the fiber optic box that can be added to the order.
Besides this, it's already wireless CarPlay or wired Android. Just pick a price point above 2g RAM.
https://www.aliexpress.us/item/32568...Cquery_from%3A
Dervish (07-02-2024)
Old 07-03-2024 | 06:07 PM
  #67
JG 996T's Avatar
JG 996T
997.1 owners can buy a pccm+ from porsche.
Old 07-04-2024 | 09:37 AM
  #68
Dervish's Avatar
Dervish
at almost 10x the price of the Ali units
Old 07-04-2024 | 04:21 PM
  #69
RAudi Driver
plus it's made in China so probably not much different in terms of internals.
Old 07-04-2024 | 04:43 PM
  #70
ngng's Avatar
ngng
Does anybody know what the head unit weighs? I did a radio/bose delete on my car but woudln't mind adding this back for just maps/phone charging.
Old 07-07-2024 | 03:18 PM
  #71
RAudi Driver
Bravo, that looks absolutely perfect in there.
Old 07-07-2024 | 03:48 PM
  #72
Vocan's Avatar
Vocan
I'm leaning towards giving this a go but it seems a fair bit more involved on a sound package plus equipped car because if you use the wire harness as-is the sound will be double amplified. I found this post in the other thread from someone who did the install on a sound package plus 987 and I imagine we'd have to use a similar process:
https://rennlist.com/forums/997-foru...l#post18737135
Out of curiosity, has anyone tried this install on a SPP 997.2 GT3/RS to confirm? If not, I don't mind being the guinea pig.
I'm also a bit overwhelmed by how many different versions and brands there are of essentially the same head unit with minor spec differences as the item descriptions on the AliExpress listings aren't always clear. For example, I'm trying to figure out if every variation has the unamplified RCA pre-outs like the picture above shows.
myw (07-17-2024)
Old 07-07-2024 | 04:50 PM
  #73
flat6fan18's Avatar
flat6fan18
Do they make this for a .1? It looks oem in a .2
Old 07-07-2024 | 07:45 PM
  #74
RAudi Driver
They make the unit in gray also.
\997.1 Unit
flat6fan18 (07-08-2024)
Old 07-08-2024 | 03:53 PM
  #75
ffc's Avatar
ffc
Well I bought one of these after finding this thread and so far it's all good. It's easier to fit than the exterrnal boxes that connect into PCM 3 and only needed one additonal cable to connect the car GPS unit to the head unit SMA male to FAKRA C male. I just removed the PCM 3 unit, connected the adapter cable, FM antenna cable and GPS cable then pushe it in. The fitting was a little loose as other have said, so I added some velcro to the top and bottom of the unit and it's all good. My car (997.2 GT3) has the base stereo so no extra bits to work about.
myw (07-17-2024)
Quick Reply: AliExpress Head Unit install
