997 GT2/GT3 Forum 2005-2012
RS 3.89 R&P and 6th gear conversion..
Old 02-17-2024, 02:29 AM
  #76
powdrhound
powdrhound's Avatar
Received 1,846 Likes on 1,081 Posts
Originally Posted by JG 996T
kevin @ umw sells a 4 liter clutch kits….reasonable price if recall right
from umw-Kit includes
Sachs Race Engineering 487 Pressure Plate "Bolted"
Genuine Porsche 4.0 Liter GT3RS Clutch Disk
Flywheel , Ring Gear , Pilot Bearing
Pressure Plate Bolts and Flywheel Bolts
Throwout Bearing , Guide Tube , Nylon Bushings
Clutch Lever Shaft Seals , Fork Shaft Bearings
$2,895.00
None of the UMW kits are using ALL the correct 4.0RS parts even though he calls it the 4.0 kit.
Based on looking at the pictures on his website, those kits appear to have the heavier 11lb 964RS flywheel (used in the 7.1RS) and not the 4.0RS/Cup flywheel. The 4.0RS one is about $300 more expensive. The pressure plate used in his kit is the 487 instead of the OEM 4.0 pressure plate. The 487 uses much heavier straps which give it substantially more clamping force at the expense of a heavier pedal. The 487 is appropriate for a turbocharged application due to its greater force which will hold up to 700 ft.lb torque. I've used the 487 on my 800whp track car with the 4.0RS/Cup flywheel and the Cup sintered disc. It's an excellent flywheel but there is no need to use the 487 in a GT3 with its 300 ft.lbs of torque. The only thing you gain is a substantially heavier clutch pedal. The OEM 4.0RS plate is about $500 more expensive than the 487 one.
With all the "kits" available on line, make sure they tell you the exact part numbers of each part so you know what you are truly getting. Trust, but verify....
changster123 (02-18-2024)
Old 02-17-2024, 03:01 AM
  #77
powdrhound
powdrhound's Avatar
Originally Posted by jreifler
So if you just wanted the FW / Pressure plate and were keeping your existing clutch in an RS car, which of those parts from the Clutch listing would you need ?
If you have a 7.1RS with a LWFW clutch you need the following 4.0 parts:
997.116.027.91 Pressure plate
964.102.239.81 LWFW
928.102.151.01 FW bolts (9x)
931.102.111.02 Pilot bearing
997.116.013.92 Clutch disc
944.116.080.01 Release bearing
The release bearing is optional but a good idea to go new on this.
You guys are making this too difficult. Took me 10 minutes to come up with this. Google is your friend. Total for everything is $2587. If someone is converting from a DMWF then you'd also need the ring gear and the guide tube which will add $234. Again, for a DMFW to a true 4.0RS clutch, you're into it for $2821 plus shipping. Porsche has really gone up in price on the OEM 4.0 pressure plate. They were $500 cheaper 6 months ago. Even so, it's still a far cry from $4K that many are claiming....
https://porsche.oempartsonline.com for the pressure plate
https://www.rmeuropean.com for everything else
The following 4 users liked this post by powdrhound:
changster123 (02-18-2024), jreifler (02-17-2024), LCCHOU (03-04-2024), RAudi Driver (02-17-2024)
Old 02-17-2024, 12:44 PM
  #78
RAudi Driver
RAudi Driver's Avatar
Received 2,899 Likes on 1,718 Posts
964.102.239.81 LWFW
I have .1 RS and if I did this what would the change feel like. What are the benefits of doing this? Genuinely interested.
Old 02-17-2024, 01:21 PM
  #79
jreifler
jreifler's Avatar
Received 1,027 Likes on 487 Posts
I’ve been chasing down opinions on this for a couple weeks, as I’ll have the opportunity next month when I drop the trans for R+P regear. What I gather is that the 4.0 LWFW for our cars will make it even more responsive and faster revving, and some prefer the feel of the 4.0 clutch as well. I’m not hearing anyone tout this as a revelatory improvement, but rather incremental on an RS car with a LWFW to begin with. Several I’ve chatted with who have 7.1 and .2 RS and non experience say not worth it UNLESS you’re already in there, or in need of a new clutch anyway. A little less expensive on our cars, and no need to upgrade pulley either.
My car has 15k miles, so clutch is fine, but I am soon to be in there, and addicted to unnecessary mods. So . . .
The following 2 users liked this post by jreifler:
changster123 (02-18-2024), RAudi Driver (02-17-2024)
Old 02-17-2024, 01:25 PM
  #80
rafter75
rafter75's Avatar
What is it gonna cost to have the R/P regear done?
Old 02-17-2024, 01:30 PM
  #81
jreifler
jreifler's Avatar
Depends on where (local v shipping and labor) and whether you also change 6th, but I have a quote for around $6k for install into box and part itself without 6th. I will save some on labor because I am friends with my mechanic and will do removal and install into car with him.
Old 02-17-2024, 01:34 PM
  #82
powdrhound
powdrhound's Avatar
Difference is very subtle. The 4.0 pressure plate and disc are more durable
The following 3 users liked this post by powdrhound:
changster123 (02-18-2024), JpCrp (02-18-2024), RAudi Driver (02-17-2024)
Old 02-17-2024, 02:59 PM
  #83
TD_05
TD_05's Avatar
Great thread thanks to all that have contributed especially @powderhound for a few PM's on the topic. I am on the fence about doing the 3.89 R&P, Guards diff, LWFW, +/- 6th gear for my "canyons" only .7 GT3. I'm not sold on the 6th gear as I am rarely on the interstate in this car. Does anyone have opinions as to ANY downsides on this? I'd guess NVH is the only, aside from the money that would eventually be spent on something else less enjoyable.
The following 2 users liked this post by TD_05:
Old 02-17-2024, 03:49 PM
  #84
jreifler
jreifler's Avatar
Agreed, and kudos to @powdrhound for the wealth of knowledge. Not doing 6th is probably only a downside if you do extensive interstate driving / road trips. If you're asking more generally about the entirety of the mods, the downside would be additional wrinkles from excessive smiling.
Chatter from the FW is your only added NVH. I love it, but not everyone does. The LSD is a night and day improvement, as is the flywheel, and the re-gearing by all accounts is also huge (but I've yet to actually drive a 7GT re-geared).
Old 02-17-2024, 03:55 PM
  #85
jbse39
jbse39's Avatar
My .2 GT3 was 90% track and 10% street but that is changing but then I did R&P, LWFW with 4.0 clutch, and Porsche Motorsport LSD (Guard was out of stock), I passed on the 6th gear replacement. It was only going to reduce a couple of hundred RPM (can’t recall the exact figure) and I have driven 4+ hours with reduce gear ratio 6th gear and I though it was entirely acceptable, but then I am sure it is subjective. The car is so much more enjoyable on the street with reduced ratio.
DD GT3 RD (02-17-2024)
Old 02-17-2024, 05:23 PM
  #86
DD GT3 RD
DD GT3 RD's Avatar
I didn’t do the 6th gear change when I installed 3.89 R&P. Rarely drive on freeway unless to the racetrack. I’m fine going 2hrs each direction. I have side muffler deletes and stock center. Maybe if I was straight piped I’d get annoyed but it’s fine for me
Old 02-18-2024, 09:31 PM
  #87
christallon
christallon's Avatar
I mean, if you're in there anyway why not go all the way? 4.0 drivetrain sounds epic to me. I love my 4.0 setup (although w standard gearing and R/P), I haven't had anything else. Clutch is easy to engage, sport purpose and all, and the bag of nails is sublime. I'd also do the 6th gear. At the end of the day, if you ever decide to sell it, and let's be honest, we all will eventually, it'll be an easier sell as the story will be a pure 4.0 setup, which is a great story to tell and sell.
I Love spending OPM :-)
The following 2 users liked this post by christallon:
JpCrp (02-18-2024), jreifler (02-19-2024)
Old 02-18-2024, 09:44 PM
  #88
powdrhound
powdrhound's Avatar
This was exactly my thinking when I did this. From an originality standpoint, having a complete A-Z 4.0 RS drivetrain will add a lot more value to the car than a half baked one if one ever decided to sell it. The 6th gear is only an extra grand which is nothing in the scheme of things. Porsche really got it right with the 4.0RS so it made sense to go all the way on this.
JpCrp (02-18-2024)
Old 02-19-2024, 01:34 AM
  #89
christallon
BTW, Powderhound, you are an asset to this board and to Rennlist in general. Thanks for all you share. You are that voice we can all count on.
changster123 (02-19-2024), jreifler (02-19-2024)
Old 02-19-2024, 01:38 AM
  #90
powdrhound
powdrhound's Avatar
BTW, Powderhound, you are an asset to this board and to Rennlist in general. Thanks for all you share. You are the voice we can all count on.
Cheers brother!
Quick Reply: RS 3.89 R&P and 6th gear conversion..
