Bucket seats and airbag coding
#46
#47
Lol that's true
#48
Damn. Cleared instrument cluster fault codes, turned off what was recommended here, still airbag light stays on, on the dash. I'm using a Durametric Pro.
Any suggestions? lol
#49
How many attempts? I vaguely remember that I had to try 3 times or so until it actually worked with my Durametric Pro.
#50
At least 3 times I tried to clear the code. Can try again. Would be nice to not have that stupid red light on
#51
Ok so now only the driver and passenger side thorax error codes are showing. I’ve erased fault codes and turned the thorax settings on and off a few times. Is it because I’m using a Durametric pro?
#52
It’s not the Durametric because I was able to do it with mine. I will take a look at mine when I have a moment to see what everything is set to.
#53
#56
Did you reset the ECU after making the changes? You will need to do that as well.
I think the only reason why I had to do it a few times was that I use a mac running parallels and that could be finicky with the Durametric software.
#59
Thank you for all this, much appreciated
#60
There is an option to reset the ECU under the same drop-down as resetting the service message. That needs to be done. It is recommended to make a backup file first. I, however did not make a backup. Once you reset the ECU, on startup the airbag light will blink 10 times then go out.
