Update on my extra oil consumption
Old 08-23-2016, 12:37 PM
  #61
gopirates
gopirates's Avatar
I believe it is 1 quart every 1K km e.g. 620 miles.
Old 08-23-2016, 02:22 PM
  #62
EMC2
EMC2's Avatar
997.2 Oil consumption data below from the owners manual: 1.6qt per 622 miles
Old 08-23-2016, 02:48 PM
  #63
mwolfe
mwolfe's Avatar
My indie shop told me the 1 qt in 600 mile sis OK. I am at about 1 qt per 1000-1200 miles.
Old 08-23-2016, 02:53 PM
  #64
gopirates
gopirates's Avatar
So back on topic, does anyone else think it is a good thing long term valuation wise if they put a new engine in? Or will there be a black cloud over the car with a new replaced engine?
Old 08-23-2016, 02:56 PM
  #65
Bruce In Philly
Bruce In Philly's Avatar
Received 1,562 Likes on 940 Posts
Very good question.
How would a consumer know? Does a commercial buyer check? When you trade a car in to a dealer for another car, do they check? I really dunno. Any experience with this?
Back in the early 2000s when these engines were blowing, the consensus of the forums was yes it does drop value but that was 'net buzz.
Peace
Bruce in Philly
Old 08-23-2016, 03:08 PM
  #66
rbennett
rbennett's Avatar
In the 930 forum it's considered a golden car if you can say "Matching Numbers" in the title of your car.
That is the Body/Engine/Chassis all have the same SN's when it left the factory.
I really don't think its going to hurt the long term value of a 997 for having a Tran/Engine replaced because of the sheer number produced.
When I bought my 2010 C2 I saw the PDK was replaced at 32k and it didn't deter me one bit. It's one of those good things bad things, bad it happened but good they took care of it
It will have a big impact on resale on say a 80's 930 or a 70's 911 RS where the production numbers were way
lower and have become marque cars.
Old 08-23-2016, 03:56 PM
  #67
gopirates
gopirates's Avatar
I seem to recall reading where engines were replaced due to IMS failures the replacement engine has a different/deviated serial number and there is a nomenclature for the serial that specifies it is a replacement engine. I would imagine this process has not changed.
Old 08-23-2016, 04:12 PM
  #68
Jastx
Jastx's Avatar
It will be a used car, not a museum collector piece, correct? It's a seven year old car now. If I were considering buying it, I'd see a brand new motor as a plus where they probably learned a few things over the last seven years and the new motor is better for it.
Old 08-23-2016, 04:38 PM
  #69
GTS Sully
GTS Sully's Avatar
Okay, so what am I missing, if anything? Pic of my running GTS that just hit exactly 3001 miles since purchased last December. Oil level shows full.
Old 08-23-2016, 07:12 PM
  #70
gpjli2
gpjli2's Avatar
[QUOTE=GTS Sully;13548463]Okay, so what am I missing, if anything? Pic of my running GTS that just hit exactly 3001 miles since purchased last December. Oil level shows full.
You need to return your car for one that uses 1.6 qts of oil in 622 miles
Old 08-23-2016, 07:25 PM
  #71
m3pete
m3pete's Avatar
My 2012 GTS also shows the same full level after driving approx 2500 miles since purchase. My has a lot of stop and go in town driving as well as high rev spirited driving on back roads.
Old 08-23-2016, 07:36 PM
  #72
rbennett
rbennett's Avatar
Holy crap thats a lot of oil! I'm at 1k mi on my 997.2 and the level shows almost right at full.
My old Air Cooled 930 that loves to bleed oil never approached that much consumption.
Old 08-23-2016, 08:43 PM
  #73
GTS Sully
GTS Sully's Avatar
[QUOTE=gpjli2;13548879]
Old 08-23-2016, 09:08 PM
  #74
ADias
ADias's Avatar
There is a forum paranoia about oil levels. Thriving to keep the oil level gauge at max is fraught with problems in a flat engine. Good practice when changing oil is to keep the oil level one step below max and never add oil above that.
Old 08-23-2016, 10:50 PM
  #75
GTS Sully
GTS Sully's Avatar
Picked mine up CPO'd from Brumos in Jax, FL and haven't added a drop since delivery. Nor has it apparently burned a drop.
Quick Reply: Update on my extra oil consumption
