View Poll Results: Poll: Have you had bore scoring on your 997.1 or 997.2 engine?
Yes, 997.1 (05-08 MY)
138
14.38%
Yes, 997.2 (09-12 MY)
17
1.77%
No, 997.1 (05-08 MY)
515
53.65%
No, 997.2 (09-12 MY)
290
30.21%
Voters: 960. You may not vote on this poll
Poll: Scored cylinder failure for your 997, Y or N? tell us (yr, 997.1 or 997.2)
#121
"Bore scoring can happen with any engine design"
Why isn't the subaru forums littered with bore scoring threads then?
The 996/997 motors are more prone to scoring than other engines out there. The tapering of cylinders due to porous engine cases/cylinder walls is a porsche problem. If I was shopping for a 996/997, I'd be requesting a bore scope as part of the PPI. I didn't request that when I bought my last Honda or Subaru - don't have to. This motor costs $15k to build yourself, you want to make sure the one you get is a good one.
IMHO of course
IMHO of course
#122
IMHO of course
IMHO of course
https://forums.nasioc.com/forums/sho....php?t=2600021
https://forums.nasioc.com/forums/sho....php?t=2225061
https://forums.nasioc.com/forums/sho....php?t=1963364
https://forums.nasioc.com/forums/showthread.php?t=58789
And BMW....
http://www.m5board.com/vbulletin/e39...leeve-use.html
Corvette...
https://www.corvetteforum.com/forums...-too-deep.html
Honda......
https://www.3geez.com/forum/3geez-ac...s-how-bad.html
Toyota....
https://www.yotatech.com/forums/f116...ed-not-217142/
Any design can have bore scoring problems.
#124
They are......
And BMW....
https://www.youtube.com/watch?v=nK43Jtv_908
Corvette...
Honda......
Toyota....
And BMW....
Corvette...
Honda......
Toyota....
Bore scoring happens as often on Porsche as Subarus go through head gaskets. Head gasket in a subaru is a days labor and the cost of machining the heads and new gaskets. Build a 3.6/3.8 N/A lately? The cost is sickening.
Being a Porsche mechanic also, I feel the need to take up for the trade a little bit. These M96 engines suffer from bore scoring more than any engine type I have ever seen in my 40 years of being a mechanic. And the symptoms are not typical of other engines that have bore scoring. Any mechanic who does not know how unique and widespread this problem is will find it hard to believe.
#125
I saw this filthy exhaust on a 3.6 997 at my indy and thought scored bores had struck here in sunny California. Turns out it was just a bad coil pack and a cylinder was running rich. I guess the tailpipe isn't a reliable indicator.
#126
Bore Scoring
2007 C4S, 23,000 miles. This is bore 6, bore 5 is similar and I stopped there. I have not had the car that long so I think this happened earlier in it's life. The car does not have any symptoms at this point. No sounds, no oil usage, no dirty exhaust tips, plugs very clean. The dealer says not to worry about it unless it exhibits outward symptoms but I'm not sure that is the best plan. I'll start with a DIY compression leak down test and then make a decision. Its a weekend touring car so maybe a wait and watch approach, or maybe a complete preemptive rebuild. The car is otherwise flawless, highly optioned, and fun as heck to drive so I'm not to upset about it. I figure rebuilding the engine is about the cost of depreciation on a new 4S the first year, and I'm a real fan of the 997 appearance and feel.
#127
It doesn't look significant at this point. Interested to hear your plans for the compression test.
You are taking it admirably and I 100% agree on the economics of the rebuild. A buddy just bought a 2014 for almost half the original list price. That means the prior owner lost $80k+ in depreciation during 2yrs of his trouble-free warranty.
#128
The car was purchased new in northern CA and then that owner moved to Colorado and had the car there for about a year, so it got a couple thousand miles in a cold weather area. The second owner brought it back to the San Francisco area and put a a couple thousand miles a year for his eight year ownership. Service history shows oil changes at Porsche dealers every 1-2 years never exceeding 5000 miles. Tires replaced at 14k miles and I can see by looking at them that the car has not been tracked since they were installed.
#129
Keep us posted what Jake says. Lets hope it doesn't require a rebuild but on the bright side, a Raby 4.0 4S with those low miles would be a special car.
If you are in the Bay Area there are a bunch of guys in Marin and would love to meet up on our next drive.
#131
I put a clutch in it when I bought it because I did not like the feel, the disk was 80% but the clutch plate and flywheel had been heat damaged so the clutch engagement was not smooth. I think the clutch had already been replaced once before and I would think just from poor driving technique and stop and go traffic. The rev counter has a total of 6 seconds at condition 1 plus 1 second at condition 2 and nothing in 3-6. Over 11 years that seemes pretty good. Average speed works out to 27 mph since new. The second owner was in his 60s and driving around the Bay Area traffic so I would think if anything the car was lugged too often which really loads the thrust side of the piston.
I have been doing car restoration as a hobby many years (mostly vintage Corvettes) so I do most mechanical work myself. Porsche’s are different, but still just a car when it comes to working on them. I own a aircraft grade articulating borescope so I did the inspection myself. Still, the depth of the marks in the cylinder wall is difficult to interpret since I have little experience with inspecting for scoring or follow up tear down to verify the accuracy of the interpretation. I sent a photo link to Raby to see if they would take a look, and will combine that info with the results of a compression leak down to determine if I will take any action at this time. Meantime since there are no symptoms and it runs fantastic we will continue with our usual Sunday road trips and not worry about it. I’ve gotta think that if more cars were scoped, results similar to these would be very common. I would bet 98% of these cars would never get scoped without symptoms. I only did mine because I had the equipment and a free afternoon.
#132
Thanks for the input Charles and I agree completely. Raby also got back to me personally with a prompt and well considered response to my list of questions.
#134
Tonight I did some interesting further investigation. I scoped the other cylinders and found varied but similar results in all cylinders in both banks 1 and 2. I started thinking about the Hartech article I read about it being very hard to tell if you are looking at polishing lines with no consequence or actual score marks with depth. The light in the camera really highlights the polished areas and will make them look like more than they are. So I decided to scope my 2013 Volvo with 36k miles and my 64 Corvette with 1k miles (since rebuild) and they looked the same with areas of vertical lines very visible in the camera. In no case on my 997, Corvette, or Volvo could I conclude that these lines have any depth. All cars, including the 997 are without symptoms. So either I have a lot of engines to rebuild or I need some more experience with the camera. 😬 The thing is, I would I guess that others may also have trouble with this, including some professionals. So at this point I fell pretty safe saying I don’t have a bore score “failure” in my 07 C4S. Time will tell.
#135
