MT Transmission gritty shifting woes
It started out as a sometime crunchy shift into second to randomly not going into first at red light.
Insisted on a test drive with a master tech and he was able to reproduce after a couple of miles of driving. He was a little cagey but acknowledged the problem but insisted that it could be shifter cable or synchro. they opened things up and after 2 weeks ordered a new box from germany. think the dealer had to exhaust all other options before calling the cpo for a new tranny.
Got a new tranny under CPO. Took a month but worth the wait.
Good luck with your test drive
Today, the "Ambassador", tech, and master tech all drove the car and declared that the notchiness is within norm.
So I ordered 2 gallons of Mobilube PTX from Suncoast since it is developed specifically for the porsche synchros, and it seems to have helped here:
https://rennlist.com/forums/997-foru...-gear-oil.html
I'll update once it's in.
For the time being I skip the 2nd while the car is not up to temp.
look forward to your update
Standing at red light, can't put it into 1st, just blocked (happens 20% of time, cold or warm)
Shifting from 1st to 2nd feels notchy but no poping out.
My indy changed the gear fluid and checked for shavings in the old fluid (found minor particles). Situation did not improve after change. Indy said to drive snot out of it and then tear tranny down and replace synchros.
Regards,
CF
Popping out of second sounds like a synchro problem unless you are causing the car to lurch via clutch or gas pedal for some reason.
Cheers
This Dealership purchased two Porsche Dealerships and did not do the original install. However the Mechanic that worked for Plaza Motors that did the install works now for Porsche of St. Louis.
I may see if the Local Indy can look at this. The issue is that all of these places are about 1.5 hr drive each way.
thanks for your reply
I am going to try switching to Mobilube PTX also may start double clutching my 1st to 2nd shifts.
I don't think this is unique to Porsche. I have owned 15 cars with manual transmissions and all them exhibited related behaviors--to varying degrees.
I suppose this due to the fact that virtually all transmissions are either designed by, built by, or have their origin with ZF, Getrag, Aisin, or BorgWarner. And I think there is plenty of technology sharing between those manufacturers.
First off.... I can't believe these transmissions are this sensitive to oil type but it appears to be so. The issue appears to be the GL 4.5 rating which is related to friction modifiers... or the amount of slipperyness. This is not a weight issue as the GL rating is another denotation of oil characteristics. This is important because our transmissions are transaxles and not pure transmissions or differentials. Again, I am just pulling in stuff I read on these forums.
Read this thread and in particular, post #17 by GTgears.
https://rennlist.com/forums/997-foru...-synchros.html
Another:
https://www.lubrizol.com/DrivelineAd...arOil/GL5.html - Describes each GL rating and note there is NO 4.5
http://www.widman.biz/uploads/Transaxle_oil.pdf Describes the protection of differing components of GL 4 and GL 5
If you google GL 4.5 and the oils weight, you don't come up with anything. It appears that this Mobilube stuff is specially formulated for our transmissions. Why? Well I am tired of second guessing Porsche's recommendations. That is what Porsche denotes in our manuals, and therefore that is what I will use. And guess what? It worked.
As others have noted, our transmissions are quirky. But still, it should not jam just going into 1st gear. Before you freak out that your transmission is failing, I recommend doing these two things in this order:
1) Shift in straight left-right, and front-back lines. Do not move in an arc. Straight lines will move one cable and therefore one internal mechanism at a time. Moving in an arc moves both cables at the same time and therefore, notchy or not smooth shifting.
2) Change your oil using exactly what Porsche recommends.
Peace
Bruce in Philly
