MT Transmission gritty shifting woes
#31
Bruce - you are probably right. I read on a another Porsche forum that the oil is SPECIFICALLY developed for "problematic" Japanese transmissions with known syncing issues. The fully synthetic oil also makes it more stable from viscosity perspective from cold to warm.
I have looked for the PTX but only found the Mobilube SHC 75w-90. Now I have ordered the PTX from nearest Porsche Center. They didn't have it in stock but have ordered it. Bruce - I report here and send a PM to you when it is done. If improved - you could officially be PTX Bruce or Gearthrow Bruce
#32
I have looked for the PTX but only found the Mobilube SHC 75w-90. Now I have ordered the PTX from nearest Porsche Center. They didn't have it in stock but have ordered it. Bruce - I report here and send a PM to you when it is done. If improved - you could officially be PTX Bruce or Gearthrow Bruce![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Peace
Bruce in Philly
#33
I assume
http://suncoastparts.com/product/00004320420L.html
2 gal will that be enough ?
thanks
#35
Bruce
I assume
that this is the right stuff since your name is under the reviews
thanks
I assume
thanks
Peace
Bruce in Philly
#36
For the record, I thought these are 1 gallon jugs they are selling at suncoast so i ordered 2. THe website unfortunately does not mention the quantity in each bottle. I need 3L for the transmission and 1L for the front diff. With US quarts, I used about 4.5qts (some leaked out as I filled up.
I think I'll up my order to 5 bottles total.
#39
Those DIYing their trans oil change should check this out:
http://www.renntech.org/forums/topic...-and-capacity/
Note this newer transmission has two plugs, one is higher than the other. My indy changed mine and he made the mistake of unplugging the higher plug. I provided the three, one liter bottles of PTX and he came back to say he needed more. I went under the car and saw his mistake. He unplugged the lower bolt and sure enough, the fill was perfect.
This indy tech was new to my indy's shop but came straight from a Porsche dealer where he worked for many many years. Mine was the first 997.2 transmission he did this work on.
By the way, the transmission in 997.2 is a Japanese-built model by Aisin.
Peace
Bruce in Philly
Peace
Bruce in Philly
#40
I hate to say this but popping out of gear is a classic worn synchro symptom. Crunching shifts with balk type synchros is also a symptom. In any case, good luck with the outcome.
#41
Peace
Bruce in Philly
#42
I suspect you are correct. Others have changed their fluid without improvement. I worry that I have wear damage and that changing the fluid just purchased me time. True or not? I dunno. I will never know until the thing fails or I pull the transmission and look inside. The darn thing is a black box. But right now, it is as good as new.... and yes, a bit quirky.
Peace
Bruce in Philly
Peace
Bruce in Philly
Do you run a short shifter? What kind?
#43
#44
Peace
Bruce in Philly
Peace
Bruce in Philly
Here's how mine looks like:
#45
I installed the Numeric shifter myself and have it in the standard length. There is different pivot points with this product but I didn't want a short shifter. I drove a short shifter and I don't get it... not for me.
I contributed to this thread:
https://rennlist.com/forums/997-foru...-1-of-5-a.html
Peace
Bruce in Philly
Peace
Bruce in Philly
