Making a Durametric Coding options Manual
#91
you must have changed something else - I somehow got the horn to go twice on locking, no idea how.. (but comfort windows works!)
#92
I got it fixed……somehow! There seems to be no rhyme or reason with the programming on my 997. I had the coding the exact same but at one point only the driver side window would roll down. I’ve changed the exact same settings on both doors and then neither door will roll down then I go through and re-change them back and miraculous both windows of roll down. 🤷🏼
#93
Peace
Bruce in Philly (now in Atlanta)
#95
Is coding the seat belt chime for a 997.1 possible with a Foxwell NT530? I have changed the side marker function and browsed through the rest of the options, but I cannot find the seat belt chime to turn it off.
Is it common for people to change the settings from auto/manual chassis? When I got my scanner, the car was set to auto even though it's a 6 speed. The only difference I've come across after switching it to manual is I have to press the brake pedal to start the car (and obviously the clutch).
#96
You can.
#97
#98
If that bugs you then you can turn that off via coding as well. It’s called “Press Brake to Start”, or something like that, and can be activated or deactivated. I saw it when looking for something else with my Launch X431, but can’t remember where.
#99
In my '06 997.1, I had the dealer code via PIWIS II comfort closing/opening and convenience closing/opening all to "on". The tech had to roll the windows all the way down and then all the way up to reset the module... works perfect! I can open/close the windows from either the key fob or the driver's door keyhole.
#102
I have a 992.2 S9 cab and a PIWIS 3 and Im just getting stsrted to program a few custom items. Ive set the foglights to remain on regardless of high beam status, side markers are now side markers and side lights, and thr light on the chronic turns on when instrument panel lights turn on.
Any suggestions fofbwhats next? And if someone can assist activating navigation and Aux input in the PCN system that would be appreciated.
#103
#104
@TortugaTortuga
Did you ever find why, and the solution for your issue with the double beep and 8009 Door h. button, inner sh. stroke code?
I am having the same issue. I get code Door h. button, inner sh. stroke and my car is not locking the doors, and I get the double beep. The radio is not turning off. Please help with any ideas. Thank you!
#105
@TortugaTortuga
Also on another note. Probably answer is no but I just got straight pipes with no cat. I assume there's no way to ignore the 02 sensors with piwis right?
