Why? Fixed 1st gear jam with new PTX gear oil
#241
I swapped fluid for a friend ... jackstands. Tight space under these cars. $30 for a lift is a deal and worth the wait, especially considering how cold the cement floors get in your territory!!! Good luck.
#242
About a month ago I had my indy install the Function-First Delrin Cable-End upgrade at the ends of the shifter linkage. I have to say that IMMEDIATELY after picking up the car, the "shift into first jam" just disappeared. Cold starts during below freezing temps, driving in city traffic, etc., 100% better. I highly recommend considering this upgrade for about $175 plus labor if you don't want to DIY.
#243
#244
Saved Again by Mobilube!
2009 C2S 121K miles MT
So I noted in a few prior posts that my shifting was getting balky.... jamming going into 1st. So I just had a Getty station replace my Mobilube PTX and WOW again. Butter. Problem solved. I asked this in my original post: WHY? This time, I started getting the balky shifting at 35K miles on the then new PTX. 35K is not the 120K mile interval noted in my owner's manual. This is way off.
History: I don't know actually how many miles I had on my car when I first started getting the 1st gear jam but I finally had it and did my Hail Mary pass and had the fluid replaced with Mobilube (as spec'd in my manual) at 86K miles. Fixed..... then it started jamming at around 30K miles later (116K). At 116K, the jamming was not serious at all but I am hyper aware of this but yes, it started getting crunchy. Now at 121K, I had what I call a serious jam..... engine cold (yes a did a very light warmup) but at a light it jammed and I got a honk from the guy behind me. DONE! Change it!!!! I threw the Suncoast-sourced oil in my frunk and drove around until I found a Getty station that did full service.... I was ready for a bunch of hacks so I had my torque wrench and a hand crank pump to help them out... but these guys had all their own tools and knew what they were doing. They had a pressure pump tank dedicated to gear oil (yes, there was probably a tiny bit of contamination with another gear oil.... but the pump tank was empty so I didn't care). They pumped in the three quarts ($115 from Suncoast) but it was not completely filled. I was ready.... I asked them to keep a quart of the effluent... so they put back in some of the spent oil to top it off..... very little.. not sure but really it could not have been more than a 1/2 pint if that. I didn't care.
So I have a sample of the spent Mobilube with 35K miles on it and I am sending it to Blackstone for analysis. Porsche says this stuff should last 120K miles .... ha!!!
You do not have to suffer with a jamming 1st gear... change it for what is spec'd in your manual.... Mobilube PTX.... and beware, dealerships may not stock it and will fill with common Delvac.
My new service cycle for Mobilube PTX manual transmission fluid change is now 30K miles. Done. I will now order 4 quarts as it looks like my car takes a bit over 3.
Peace
Bruce in Philly
Peace
Bruce in Philly
#245
Peace
Bruce in Philly
Peace
Bruce in Philly
#246
2009 C2s 122K miles MT
Got the BlackStone report back where they analyzed my 35K miles of use PTX fluid. Remember, Porsche notes this fluid should last 120K... they state this in my manual as the change interval. I have no real idea what to make of this except I am out $20. What I am happy to hear in their comments is not metal wear.... I am always worried that my 1st hear jamming may be do to something failing in there.... maybe this jamming is just part of the charm.
I put a message in with my sample noting I was getting some sticking in the transmission as the fluid aged/miles driven and wanted to know if the oil breakdown is somehow to blame. BlackStone commentary:
"Metals in this sample look fine, so there's no evidence of poor wear as a result of the issues you
noted. The viscosity was thin for PTX 75W/90, but we're not sure if that would account for the stickiness.
Universal averages show typical wear levels for a manual Porsche transaxle after ~14,60000 miles on the
oil. You ran 35,000 miles on this oil and wear metals are well below average levels. No water or other
contamination was found and insolubles read low at just a trace. Check back in 35,000 miles again, and let
us know if the stickiness returns."
Commentary?
Peace
Bruce in Philly
Commentary?
Peace
Bruce in Philly
#247
I've been following your post with great curiosity hoping someone would have a good explanation. I've also been trying to find a detailed parts diagram for the transmission or a detailed cutaway to see if the shift shafts have ball or shaft detents that might be the cause. I know that some transmissions do, especially those with all-internal shift linkages, and if the detent in the first gear shift shaft is worn it would explain why a better lubricant might affect its operation.
Does anyone know if the Porsche manual has detents (with either ball or pin lockouts) on the shift shafts?
#250
Have to mail order it from Suncoast parts or Sunset. It's only sold to them in large containers, so they distribute it in used oil bottles that they clean. You need 3 bottles to do the drain and refill and the bottles you get won't say MobilLube PTX on them, but that's what will be in them.
IrishLegend (01-05-2021)
#251
I did the PTX oil change on my 08 997 C2 Cab about 8 months ago. It fixed the first gear issue that I have been living with for 10 years about 95% better. Every so often it happens that I can't shift into first gear when stopped at a light without putting it into second gear first. So now that I have an almost perfect 997, it is on the market because I am getting a 992.
#252
Commentary?
Peace
Bruce in Philly
Commentary?
Peace
Bruce in Philly
#253
I also did the PTX change and it fixed the 1st gear jam probably 95%. I just had my shop install the Function First Shift Right bushings, cable ends, and engine mounts, and WOW all those things made a huge difference. I also upgraded the **** to an aluminum/wood shifter and that gives a slightly more direct feeling vs the stock plastic ****.
After all that, shifting into 1st feels more positive, and there is less notchyness and vagueness going into second. Once fully warmed up, it’s rifle bolt smooth and tight. No more side to side play in the shifter at all. My transmission finally shifts how I expected a Porsche to shift!
Bruce, thanks for keeping this thread going and sharing the gear oil UOA. I changed out my gear oil with PTX Mobilube and really did not notice any significant difference. Only 25k miles but was 6 years old. BUT, as to fluid interval changes stated in the owner’s manual, these are the same people that say you can go 10k miles and 1 year to an oil change. My motto when it comes to fluids and filters has always been “if in doubt, change it out.” When I buy a used Porsche, I immediately change out ALL fluids and filters so I know what I have and I have a baseline. Oil change every at 6 mos which is usually about 2.5k miles because of fuel dilution concerns. Blackstone UOA on all oils. I also change ALL fluids and filters every 60k miles/6 years ignoring the manual. That is my maximum on any fluid. I change the transfer case gear oil on my wife’s Cayenne at every oil change (6 mos/5k miles) but that is another story. I am not going to nickel and dime my 911 on DIY maintenance that I can easily do myself on my Quick Jack.
#254
Porsche OEM Transmission Oil
Anyone get verification the currently recommended Porsche OEM transmission oil, P/N 000-043-305-49-OEM, is the same as Mobilube PTX?
Here is a source for this trans oil: Pelican Parts Porsche OEM Transmission Oil 75W-90
I would like to get sealed liter bottles rather than hand-filled re-purposed containers from suncoastparts.com, plus the 1-day free shipping from Pelican is better than paid east-to-west coast shipping from Suncoast.
Thanks for any info provided!
#255
Your concern for getting sealed official bottles is understandable... but a bit extreme IMO. I have used SunCoast's PTX now three times.... yes I have a really wonky transmission. I don't see an issue at all. BTW, you may want to get 4 quarts as it takes a tad more than 3 for mine.
Regarding what is in the Porsche bottles... no one really knows. I have read conflicting information what the factory fill was and what is in those bottles. All I know is that my manual is very specific in denoting Mobilube PTX. So for me, that is what I use and I get it from Suncoast. Odd that I don't trust what is in the Porsche-labeled bottle but two dealers near me don't even use it, they use Delvac and were unaware of what was denoted in our Owner's manuals... at least that was true a few years ago.
New Shell alternative:
Now that Shell is producing a similar product, things get different for me. If I were to buy today, I would stick with PTX from SunCoast and should that dry up, I would jump to the Shell product and the ending of PTX and emergence of Shell tells me that Porsche switched suppliers. The issue is the GL rating. GL 4 is for manual transmission gears, GL 5 is for differentials.... two different duties and metal compositions. Porsche spec'd a 4.5 as our transmissions are both (a transaxle) and PTX and now the Shell is this spec.
So here is the Shell spec sheet for their new 75W-90 GL 4.5 where they denote it is for sports cars with transaxles - It is Spirax S5: https://prodepc.blob.core.windows.ne...en-GB)_TDS.pdf
The above sheet denotes the approved cars are Ferrari, Getrag (german transmission maker... my transmission is Japanese by Aisin), and some Mercedes Benz transmission. BTW, I found it available on eBay for $9 a liter .. odd only eBay and super cheap... hmmm... just make sure it is GL 4.5.
Peace
Bruce in Philly
