PDK Problem
It is best to purchase extended warranty through your dealer before your original warranty expires. For 11 with 20k miles should be around $3k for 5 year 50kmiles.
Next thing they say you need new wind screen wipers or a new exhaust.
tho sadly, this isn't a joke and yes i can actually believe this crap came from a stealership. i cannot WAIT to hear the explanation...
Secondly,I find absolutely ridiculous and LAME for a dealer to suggest new tires just so they can make a buck,seeing that the warranty work didn't pan out and couldn't charge Porsche for the diagnostic!
However, I would not want to bet too much money on Porsche doing this.
To help yourself be sure you get an official invoice that lists your car's VIN, mileage, date/time, your complaint, the error codes, and what was done, and what was the "diagnosis", which appears to be "We don't know."
Better for you if you push to get this resolved now with the car under warranty.
Do not accept the car back. I would not accept the it needs new tires either unless the tires are severely worn (and with just 16K miles there is probably a bad alignment to blame) or the wrong tires or mismatched tires, etc.
There are too many PDK equipped cars running around with worn tires (and even *gasp* non N-rated tires) for tires I think to be at the root cause of this problem.
The dealer can contact its factory rep and enlist the factory's assistance. Many dealers do not like to do this as getting a hold of a factory rep is I've been told hard. The last word I had on this subject was they appear to not use voice mail and email is pardon the expression foreign to them. When I had my 996 Turbo in for a leaking 6-speed transmission seal it took a week or more before the tech managed to get ahold of the factory rep and confirm the factory would supply a new transmission (under CPO warranty) and to work out some apparent mixup someplace regarding which transmission the 996 Turbo required.
So, my advice would be to say that the dealer's response to your car and its error code is not acceptable and what does the factory have to say?
Also, state because of the error and the having to pull over and stop and arrange for a tow you have lost all enjoyment from having the car because of this problem hanging over your car.
If the dealer gives you any pushback remind it one major reason you bought the car was because you are assured the dealer had the service department to properly and promptly service or repair the car and if the dealer just throws up its hands at the first problem you feel you have been misled.
If the dealer is unable or unwilling to deal with this problem to your satisfaction you will be forced to contact the department of consumer fraud in your area, and write a letter to PCNA and the Porsche factory asking then if this dealer can't or worn't resolve this problem with the car under warranty where should you take the car?
Play a little hard ball, although of course always polite and calm.
Have your service manager enter your VIN and look up in their PIWIS II system the document titled: PDK Transmission Diagnosis: Symptoms and Repair Procedure (35/09). The version I have is dated Aug 31, 2012 and is 18 pages so there may be a newer version on the system now depending on your VIN. It has very detailed procedures of how to proceed given any PDK related fault code or potential leak in the system. Assuming you have a PDK fault code this is the only way PAG will allow repair to proceed on the PDK unit and since you are under warranty still, you are in a good position should the recommended procedure result in a replacement of the PDK unit (which unfortunately is a very common end point in the diagnosis process as outlined in the document).
On a side note, there are times when you get the "Transmission Emergency Run" notice without a PDK fault code being logged (I've seen this with both white and red font messages). In these cases, you can cycle the ignition off / on / off. Then restart and engage the PDK into D and move off a bit to see if you get the warning again. Typically if there was truly a PDK fault, the warning will present itself almost immediately, certainly within a few minutes of driving. In this latter case, a PDK fault code will be stored in the PDK module and readable by PIWIS II or Durametric. Lastly if you get the warning, try to take a picture of the message with your phone to document the warning for your service manager and yourself. If you don't get the warning again, consider it a software glitch and you're good to go.
Good luck.
Also, service writers make large commissions from out of pocket repairs. Tires are NOT the problem. Good luck and keep us posted!
