PCM 3.0 backup camera options?
Hurley's here in NVA (Mclean address) did the job. The hardware he costed at $600 (no doubt you can get cheaper somewhere). Not sure about any model numbers for the hardware, but I can give you Hurley's contact info if you want. Total price with tax was $1k. He does lots of Porsches.
Charlie
Thx.
Good luck.
Charlie
Man, dust in these photos shows up WAY more than it looks like in real life.
NavTV backup camera in action on 997 Targa on PCM3 with reverse gear selected.
So this March as I fired up the 997.2 Targa post winter again, and took it off the trickle charger, much to my chagrin, I discovered it had the exact same mode of failure as a year earlier. The backup video would be this washed out streaky overlay of whatever Porsche display screen the PCM was showing at the time. Made a video of it to show the installer and NavTV what the problem is.
In 2017, this was the video I made and sent them:
So it appears that the NavTV main unit failed in the same way as it did before. Thinking it over, as the unit worked flawlessly otherwise, it must have been something related to the car sitting on the trickle charger all winter, or the battery voltage discharging to low/dead and then the battery being recharged. NavTV came back with their guess at what could be happening that causes the controller to fail and what the possible work-arounds are.
1) It is not an over-voltage from the charge circuits or a battery charger that is the issue, the NavTV has power systems designed to handle that. Their estimate is that the problem is the lower voltages, that are bringing the controller in and out of powered up state or having it in a low voltage state that is causing components to fail.
2) These Porsche NavTV units don't sell high enought quantity (dozens not hundreds a year) for NavTV to do a post mortem analysis and re-engineer their power module on the solution they build; its not cost effective for the # sold and the time that would be required. So their suggested solution is:
3) Install an on/off interrupting switch on the single power line to the NavTV control module so that when you store the car or put it on the trickle charger, you flip the switch to disconnect the NavTV control unit from the power.
So I'm now planning to have a small on/off rocker switch installed somewhere, like in the glovebox, and putting warning stickers on my trickle charger and around the cig-lighter power port to remind me to power flip the switch to OFF before storing the car prolonged/using the trickle charger. Remembering will be the hard part, especially if the damage happens as the battery is discharging over months BEFORE I remember to put the trickle charger on it. If the damage happens during the discharge over time lowering of the battery voltage, there is no warning that will help, as I won't know when I'm on a path to that point.
The right engineering solution is to have a pre-circuit (well given they won't redesign the module themselves) that monitors the voltage and when the voltage drops BELOW a set limit, it disconnects the power ( a push breaker?) automatically. Then you don't have to remember anything other than remembering to push the breaker to reset it when you hop in the car in the spring and the back up camera is powered off because it put itself into safe mode.
Time to look for such a breaker that can be electronically tripped and is micro small ....
Minok have you been able to find a solution that works?
Looking at the kit I see a Toggle switch for activating the camera, could that toggle switch be used to cut the power while storing/trickle charging ?
They are replacing the failed unit under warranty (at present, for me) however, the low production volume means you can (as I am now) be stuck with a failed unit UNTIL the new batch comes in, which is months of not having a functional unit. The solution NavTec suggested is to have a mechanical switch installed inline to the power feed that would disconnect the NavTec from the car's power - so you would have to remember to flip the switch to decouple the navtec when you use the trickle charger, then flip it back when you drive the car. Thats a rather low tech and customer burdening solution to the design flaw, but it is what they are providing. I'm still driving around with the failed unit waiting for a replacement unit to arrive at the installer from NavTec... months have gone by and every once in a while I ping my installer to check with them. Not an acceptable situation, but it is the only one we get.
So if you want to have a back up camera solution for the 997 this is the best solution but it has a major usability flaw, so only use it with consideration of its limitations.
Oddly, my car came with a backup cam mounted above the license plate but the dealer had no info about it. I also found a hard wired button unit for a Passport 9500 tucked under the dash (I wish I noticed before a bought an R3!). I'll have to chase down the wiring at some point this winter. Maybe I'll be able to use the cam in the end.
Charlie
But it is a fairly advanced DIY job because it requires opening the PCM unit, adding a video card and new ribbon cables. NOT for the faint hearted. Also expensive at USD700 for the parts.
