Launch Control
Old Apr 30, 2013 | 08:19 PM
fbfisher's Avatar
fbfisher
Default Launch Control
If you have used this function, what results have you experienced? Is there really a big difference in the acceleration as compared to the car in normal, sport or sport plus mode?
Old Apr 30, 2013 | 10:28 PM
Happy911S's Avatar
Happy911S
All this does is allow you to rev the engine to max RPMs with an automatic - similar to what you would do if you had a manual. By having the engine RPMs up when you release the brake the car gets off the line a little quicker.
Old Apr 30, 2013 | 10:38 PM
SteveFromMN's Avatar
SteveFromMN
I think it is a bit more complicated. Complete computer control of clutch engagement traction and throttle control for max acceleration.
It is like being shot from a gun.
Old Apr 30, 2013 | 10:49 PM
kouzman's Avatar
kouzman
i have been drag racing for years with manual cars and i can tell you that the PDK is in another league!
i took my 09 Carrera 4S Launch Car at the strip a few weeks ago and managed an incredible 12.03@115 with a 3665 lbs car with driver! For "only" the stated 385 bhp that's an excellent time and trap speed...
Only a PDK or similar system can allow the car to launch at the maximum allowable rate.
Old Apr 30, 2013 | 10:56 PM
LT1's Avatar
LT1
Kouzman. Was that a 1.84 60 ft that I saw on the board? Incredible run. I very much doubt that I could turn a 12.03 in my 6 speed turbo. Gonna try it soon though before I mod it
Old Apr 30, 2013 | 11:01 PM
kouzman's Avatar
kouzman
The 12.03 was with 1.79 60ft...
I did another 12.1 with 1.84 60ft. The car spun more in the second run and because i was running with the PSM on it really cut the power...
With the PSM off i am sure the car can run 11s... Some spinning is actually good so the car does not bog down...
Michelin Super Sport Tires BTW...
Old Apr 30, 2013 | 11:04 PM
fbfisher's Avatar
fbfisher
Originally Posted by kouzman
... managed an incredible 12.03@115 ...
So i wonder what would you have clocked in regular/sport/and sport plus by comparison?
Old Apr 30, 2013 | 11:18 PM
kouzman's Avatar
kouzman
in regular mode i dont think you can activate the Launch Control Function... The shifts alo are much easier even if you are aggressive with the gas pedal...
Old May 1, 2013 | 05:29 PM
fbfisher's Avatar
fbfisher
^ true. Just wondering how much faster the 0-60 times, or the 1/4 mile times are when using launch control as compared to without in the various modes available to us.
Old May 1, 2013 | 06:18 PM
kouzman's Avatar
kouzman
^that would be ideal to do for comparison purposes.
But you would need to go to the track one day that you can do many runs. When i went there was a huge event, probably over 300 cars and i waited 3 hours between runs...
i might go once more this year to test the car with PSM off... I am sure i can get a 11 sec timeslip!!!
Old May 1, 2013 | 07:48 PM
stronbl's Avatar
stronbl
I've done LC a few times when I need a quick rush (non public streets). Others have already covered the differences versus normal max acceleration, but it really is like being shot out of a cannon.
Also a discussion going on about LC on the 991 board - check out post #16 video .. it says it all.
https://rennlist.com/forums/991/7521...h-control.html
