Durametric tool
thanks for your help.
Paul.
Otherwise it is a good product if you are so inclined that way ...
FWIW, i did at least code it to open/close the windows from the remote when unlocking or locking vehicle. so that's something.
Under the "Alarm" module change the following parameters under "Coding" to:
1. "Comfort Radio Remote" = Active
2. "Comfort Function Window" = Active
3. "Comfort Function Roof & Window" = Active
Be sure to backup the module before changing the parameters.
Next, you will want to go to the "Left Door" module and change the following parameters under "Coding" to:
1. "Comfort Opening" = Off
2. "Comfort Closing" = Off
Repeat above 2 steps for the "Right Door" module
It can do one thing - it resets the reminder system to the maximum interval for the car's onboard computer. For the 997.2 that means all it can do is reset it to 2 years/20k miles. Thats it.
A proper system, and what the PIWIS can do (and my VW Golf from 1994 could do) is allow the owner to set the time/miles for the next reminder manually, rather than only to the fixed 20k/2yr value.
IE, you just changed oil, and would set next service reminder to 1 yr/10k, lets say, but you need to actually do a brake fluid flush in 8 months, so you want to set the reminder to 8mos/10kmi but certainly NOT 2yr/20k.
So what DURAMETRIC can do, effectively, is turn off the reminder message. What it cannot do is set it to the proper value to remind you when your next service is needed.
I asked asked the folks at Durametric about this and their position is: the service reminder reset is to set the reminder for only the 'major service' (which I guess is 2yrs/20kmi). So you effectively have a system that will only remind you of the 'major services'. Not a service reminder proper.
Since the new car came coded with oil change at 1yr/10kmi, I know the car is capable.. just Durametric software doesn't know how to do it.
