997.2 Engine Reliability
Old 02-25-2015, 10:36 AM
  #211
CaymanPower
CaymanPower's Avatar
Originally Posted by Wayne Smith
I miss the point. The guy points out that the DFI motor will have problems because his 2008 motor had problems. Does that mean a peach will be crunchy because an apple is crunchy?
His 2008 engine is a DFI MY09, mind you. Again, he is not alone:
997.2 PSE rattle/reverb
997.2 C2
Turned out not to be bore scoring. It was a misaligned piston ring allowing too much oil in to the cylinder, hence the smoke and huge oil consumption.
All new modified piston heads and cylinder linings rebuilt under warranty and all is well.
Wouldn't worry about bore scoring in a gen2.
Yeah, we will all be hunted. Maybe it is time to change the forest we are being hunted in.
You didn't get it! I'm in the market for a 997.2 after thoroughly considered other options.
Therefore, the last thing I need is misleading information to say the least.
Old 02-25-2015, 10:51 AM
  #212
SpeedyD
SpeedyD's Avatar
997.2 C2
Im done after this post (it's been fun!) but your second link actually underscores no bore scoring (I didnt read first link), if you read the link yourself? The conclusion in that thread was that the DFI motor suffers no major reliability issues... are you googling "bore scoring" and hoping to trick people? You are digging your own hole on here...
There is clearly no major issue with the DFI engine or it would have come out on the forums by now. There will be failures, but not out of what is ordinary across any OEM/brands: Toyota, Honda, everyone experiences low rate failures and then that gets split between user abuse and actual defect. IMS was a specific, higher event issue. Frankly, unacceptably high. The problem there was in the design and implementation. It wasn't merely caused by a faulty component/mfg defect.
You realize your posts wont have any impact, at all, on 997.2 prices, the view on the brand, etc. Not sure how you are diligencing your own purchase by narrowly focusing on a non-issue and not exploring anything else on these forums... strikes as very, very odd.
Old 02-25-2015, 11:03 AM
  #213
CaymanPower
The problem was misaligned piston ring on a 997.2 DFI engine.
This thread is about 997.2 engine reliability problems.
1. Bore scoring; 2. Bad piston/piston rings are engine reliability problems...
Old 02-25-2015, 12:47 PM
  #214
Bruce In Philly
Bruce In Philly's Avatar
Received 1,536 Likes on 925 Posts
+1
Peace
Bruce in Philly (typically paranoid but not with DFI engines)
Old 02-25-2015, 02:06 PM
  #215
CaymanPower
Originally Posted by Flat6 Innovations
As a developer who shared what he learned, in a forward and direct manner with the M96/ M97 engines, I caught a lot of flack. Terms like "fear monger" didn't sit well with me.
My last 5 years have been spent researching and developing the 9a1 engines, both DI and port injected. With these I am not making the same mistakes that I made with the M96/97 engines, and sharing what I've learned online. People don't want to hear the truth, they just want to believe that its all Unicorns and rainbows in the mechanical workings within their engines. Most of them don't even believe problems can occur when their own engine snaps a timing chain and blows it through the cam cover; they certainly won't believe anything thats written.
There's a reason why we bought a new car in early 2010 and took the engine apart straight away. My record is pulling a 9a1 apart with 11 miles on the odometer.
+1
Jake, I have to agree with you. Unfortunately, people don't care about the truth.
Please, tell me if you experience with the 9A1 engine can confirm that cylinder bank #1 is the most affected and then I will be out of here.
Oh, and another thing that may help you in your diagnosis, if you have paid attention to the last two links above you can read the following in one of them:
After much debate with Porsche GmBH, pictures, measurements they're replacing the pistons (apparently 991), crank casings and rebuilding the thing.
It seems that the 9A1 engine pistons got an uprated version transitioning from the 997.2 to the 991 model. Who would thought about that?!
Jake, you also need to buy a new 991 to pull out the engine straight away and take full awareness of the "little differences" inside!
Old 02-25-2015, 02:30 PM
  #216
Flat6 Innovations
Former Vendor
Flat6 Innovations's Avatar
Received 2,290 Likes on 902 Posts
We've already got a line on the newest engine. I have had several 2014s apart already.
the new GT3 RS 4.0 will be here after the new owner drives it in stock form for 4-6 weeks, thenm its time to make it 4.2 or larger and get way ahead of the rest, again.
As for wear, my biggest issues are on bank 2, its where I see broken rings and worn cylinders the worst. There's a reason for that, and it follws the M96/97 as well as the Cayenne V8.
Again, thats all I have to say on the topic of 9a1 failures. You guys will hear enough in the future without my input. Now that my M96 book is done, ai Have already started on the 9a1 assembly manual and "definitive guide".
Old 02-25-2015, 03:34 PM
  #217
CaymanPower
Thank you Jake!
The 997.2 I'm interested in and went to see the other day exhibited a small puff upon cold startup from rear left tail pipes whilst none on the other side, that's the reason why I'm suspicious of cylinder bank #1 with the DFI engine. Also, the following picture of the 997.2's 9A1 engine shows cylinder #3, which also means cylinder bank 1. Moreover, in the cylinders from bank 1 the fuel injectors point directly downwards to the lower wall side of the horizontally disposed cylinder, which in the bank 1 corresponds precisely to the piston thrust side where the piston force is higher (it's the opposite with cyl. bank 2). Since, the coolest coolant enters bank 1 from the bottom first, it means that the thrust side will tend to run cooler and so fuel intrusion (there's less evaporation) is favoured even further on that side's wall. The necessary oil film between piston and bore can therefore be 'washed' away from the cylinder walls past the rings and promote the inevitable bore scoring. Lower outside temps only favour the phenomenon even further with the consequent fuel dilution from richer fuel/air mixture and water that is not evaporated from the oil due to a cooler running engine leading to poor oil characteristics, which adds to the problem. It's a snow ball, literally.
Old 02-25-2015, 03:52 PM
  #218
Jake Raby
Jake Raby's Avatar
Thank you Jake!
The 997.2 I'm interested in and went to see the other day exhibited a small puff upon cold startup from rear left tail pipes whilst none on the other side, that's the reason why I'm suspicious of cylinder bank #1 with the DFI engine. Also, the following picture of the 997.2's 9A1 engine shows cylinder #3, which also means cylinder bank 1. Moreover, in the cylinders from bank 1 the fuel injectors point directly downwards to the lower wall side of the horizontally disposed cylinder, which in the bank 1 corresponds precisely to the piston thrust side where the piston force is higher (it's the opposite with cyl. bank 2). Since, the coolest coolant enters bank 1 from the bottom first, it means that the thrust side will tend to run cooler and so fuel intrusion (there's less evaporation) is favored even further on that side's wall. The necessary oil film between piston and bore can therefore be 'washed' way from the cylinder walls past the rings and promote the inevitable bore scoring. Lower outside temps only favour the phenomenon even further with the consequent fuel dilution from richer fuel/air mixture and water that is not evaporated from the oil due to a cooler running engine leading to poor oil characteristics, which adds to the problem. It's a snow ball, literally.
While fuel is a solvent and will wash the oil away, you are judging a book by it's cover.
A disassembled engine, and a micrometer tell the story. After you see a few dozen the story starts to tell it's self.
Old 02-25-2015, 03:58 PM
  #219
CaymanPower
Jake, not judging by the cover... where there is smoke there's fire!
It's the smoke Jake, it's the smoke that tells you... open up the engine and all will be revealed.
Old 02-25-2015, 06:28 PM
  #220
ADias
ADias's Avatar
This La Ferrari V12 must be doomed [according to the paranoid on this thread] as it smokes differently, left and right...
Old 02-25-2015, 07:16 PM
  #221
Wayne Smith
Wayne Smith's Avatar
Received 1,195 Likes on 762 Posts
It isn't the smoke at start up, it's the color of the tail pipes at shut down. In this case start up smoke has to do with cylinders stopped on their sides (horizontally) combined with gravity (for you science believers). Smoke does not necessarily mean fire.
I'm done with this post. Too much hate. Too much effort creating negative. Not enough of how I want to spend my spare time.
If anybody has anything pertinent to say, please say it on a new post.
Signing off. Wayne
Old 02-25-2015, 09:48 PM
  #222
CaymanPower
This is what I did to my Cayman...
Original tailpipe:
Rerouting and split the exhaust tailpipes:
That was what I needed to do for Porsche to finally acknowledge the problem.
Old 02-25-2015, 09:54 PM
  #223
CaymanPower
And this is the kind of smoke I got from cyl. bank 2 and none from bank #1... but then again, despite of being the 9A1 engine it wasn't the DFI version
QUOTE=CaymanPower;9263178]
It was only until I managed to show them, by rerouting and split the exhaust tailpipes, that the engine only smoked from one engine side (bank #2) that they finally acknowledged the problem:
[/QUOTE]
Old 03-01-2015, 08:33 AM
  #224
user 72902
user 72902's Avatar
Interesting and what made you modify the exhaust into separate tailpipes?
Old 03-02-2015, 02:49 AM
  #225
gasongasoff
gasongasoff's Avatar
This is what my 997.2 engine sounded like...
before Porsche finally swapped out the motor with a refurb.
Quick Reply: 997.2 Engine Reliability
