Brake Dust Gone!!!
#31
Thanks guys. Can you comment if the dulling is permanent or if the original shine comes back as the product wears off?
To add to this, I have also read that the product doesn't seem to work well on anodized, flat paint and unfinished (polished aluminum) wheels. It seems to work best on painted/clear coated wheels.
#33
I tried this stuff and it is way overrated. It reduces surface adhesion of brake dust but over time (200 miles say) it starts accumulating. I stopped using it. I went back to my usual routine - rims and periodic washes. Washes with P21S or Porsche's rim gel and dried with are easy.
#34
I agree that one should not stop cleaning and waxing one's rims due to this product. It's simply a cheap product that'll help reduce build up of crud on your rims. Keeping the rust off the rims after washing the car is really my main use of this stuff.
#35
Yes it dulls the surface. Is it permanent? Who knows? I do not want to test it.
I tried this stuff and it is way overrated. It reduces surface adhesion of brake dust but over time (200 miles say) it starts accumulating. I stopped using it. I went back to my usual routine - Rejexed rims and periodic washes. Washes with P21S or Porsche's rim gel and dried with Vac n Blow are easy.
I use compressed air to blow dry the brakes and force the water out of the drilled rotors. I find that this virtually eliminates the rusty water spinning out of the rotors onto my nice clean wheels.
#36
I am currently conducting my own test on black powder coated fronts. One has been removed and cleaned and completely dowsed in Armor All protectant. The other has not.
I'll post what I see after I put miles on the car. (that could take a while, I don't drive her much)
#37
AutoZone has it on special for $4 a can. I ordered 4 cans tonight. They'll be in tomorrow by noon. Hope I like it. Won't know till Spring if it really works for my driving & detailing style.
I'll spray the Turbo's wheels in the heated garage, and see how easy it is to apply and what it does to the sheen on the SpeedLines shiney fat polished lips.
#38
Just purchased two cans today at AutoZone, $ 4 per can on special clearance. They will not be stocking any more ?
For now I'm going to apply to the belly of the wheel, from rear of spoke only. Fronts of the wheels are easily cleaned ( classic five spoke )
#40
I did not see any real noticeable "dulling" on my freshly RejeX wheels yesterday.
I wonder how this stuff would work on the front bumper for bugs? I will NOT try it, just wondering. Any guinea pigs?
#41
i use rejex on the whole car, and I honestly think it lasts longer than any wax i have used. I'm a big fan. It works great on protective film, too.
#43
I've used rejex on my cars and boats for years...zero issues...shines like crazy!
#44
I love this stuff. It lasts me 2-3 weeks if there's no rain, and it even kept the wheels clean after a 200 mile "spirited" drive. Can't complain about that at all.
There's also an Eagle One "Keep Clean" wheel protectant on the market, it comes in a pump spray bottle. I haven't tried it yet, but I did pick up a bottle recently.
#45
Be warned regarding the Eagle One product. You cannot control the spray from the pump and it goes everywhere and splashes as you apply it. It dries like a resin and I found it very difficult to get off, used some tar remover or 3M adhesive remover. I only tried it once, so I suppose there might have been some odd issue with my bottle or application, but I won't use it again...my 2 cents.
