What did you do to your 997 today?
415CPA (11-16-2021)
Fixed the washer fluid reservoir leak.
Was thinking replace the tank, but decided to have a looksee before ordering one.
Turns out it was the seal around on of the pumps. Pump was loose. Other one not.
A new seal would prolly fix it, but the pump intake pipe might be worn too.
Figured I would silicone it liberally and see what happens - not a big deal to get to it - so far so good.
415CPA (11-17-2021)
The start of the "winter" project - i'll post more on my thread but figured a sneak of how beautiful this FVD hardware was needed
long tube headers and cats from FVD
gt3 throttle body
And lest we forget my test fitted duck from getty:
quack
gt3 throttle body
quack
Had the 18" wheels with Summer tires swapped out for 17" wheels with Winter tires. Also fixed a slow leak in a Summer back tire, so ready for snow and the switch back to Summer tires in the Spring.
Replaced my stone guards
I replaced the stone guards on my 2005 997.1. Looked straightforward in YT videos, so I did it myself with 3M Paint Protection film. Removal of the old, cracked guards was a nightmare. They came off in small pieces with a heat gun as expected, but the adhesive took hours of tedious work to remove. Used Goo Gone and LA's Totally Awesome Cleaner, a plastic scraper, and plenty of towels. I cut new guards using a template made from the old ones, and applied the new ones in probably 10 minutes.
Right side stone guards before & after
Are you confident however that the 3M PPF is enough protection for those particular locations? (Those areas can take a beating.) The factory material seems significantly heavier in thickness...
I guess the 3M material would be much more easily removed if it looked like it wasn't offering sufficient protection.
Me too . . . How long did it take you fry ?
Just ordered the parts.
Oil Change! When I got the car 2.5K miles ago from a Cadillac dealer I could not get info on what they changed the oil with, so I ran it for 1000 miles and then swapped in Joe Gibbs BR40. After another 1500 miles, I changed to DT40. Now it's time to send both samples to Blackstone!
Up next:
Up next:
- Took the wheels to a local shop to get powercoated. Picking them up in the morning!. I know tons of people like the black wheel look but I felt like it was just too much. Maybe I'd have felt different if there was a silver lip, not sure. Getting a light gunmetal color.
- Numeric Shifter and Cable are getting installed Monday
- Double-DIN Pioneer Head unit and 12-channel Helix Amp/DSP along with XM receiver are getting installed on Tuesday
- In final negotiations with a RL member via a marketplace ad for Getty Duckbill Sport...that just happens to already be painted Guards Red
- Soul Performance valved exhaust ordered and scheduled for delivery in December, for $800 less than Soul advertises it for!
The following 2 users liked this post by 997Fanatic997:
TerrestrialFlyte (11-18-2021),
Tremain (12-03-2021)
Up next:
Up next:
