What did you do to your 997 today?
#7921
Ordered Remotekey 2 days ago. Received it and installed it today!! Now I have a dipping passenger mirror when reversing!!!
Attachment 1300655
Attachment 1300656
Attachment 1300655
Attachment 1300656
Easy?
I'd love to do this just to hear the car beep when I lock/unlock the doors!
And they never seem to go on sale?
#7922
Originally Posted by Recruiter_Bruno
How did you find the installation?
Easy?
Easy?
Installation was pretty straight forward. It did take me a bit longer because my garage was dark so I had to use flashlight, plus I was taking my time and reading each sentence 5x before each step, and I didn't want to break anything. If I have to do it again, I would say it will take me 15-20 mins. Only suggestion I have is to tap the 12V hot/ground wires toward the bottom, close to left side of the fuse box (step #7 of the official installation manual). It will make the wires neater when you try to shove everything back in. I tapped it too high toward the piece that's wrapped in plastic so it wasn't as easy to neatly bundle the wires when finishing up the installation.
#7923
Ordered it from MotiveMods. A few bucks cheaper than retail price of $299 (part# RKLBPE1 for my 997.2 without memory seat).
#7926
#7927
Originally Posted by kellen
Love this mod. Mainly did it for the windows down and up feature from the remote and the horn/alarm beep sound. Worth it.
#7928
Think my settings are chirp with lock, passenger window auto up/down, windows up/down from key.
Once or twice in 2-3 years I've had the unit reset itself, IIRC the first "function" is unit off/on. It had turned itself off, but turning it on made all the prior settings come back.
#7929
Chirp. Horn is louder. Have it set to chirp with lock only. I think chirp uses one horn tone while horn uses the full horn.
Did you tinker the setting through the usb/PC while it's installed? Or would you need to unplug the module harness first? Want to make sure it's safe to update while it's still connected. Thanks.
#7930
Installed the LAPower Bluetooth upgrade unit to my OEM PCM on my 2006 C2S today ... works really well and its great to have streaming audio and Bluetooth phone in my OEM PCM system! And ... it's got a reasonable cost which makes it even better!
#7933
Basic Sponsor
It got up to 60 degrees here so I woke her from her hibernation and went for a drive.
Found a brand new 992 to take a picture with!
I Kid.
I Kid.
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
