What did you do to your 997 today?
#6963
I've been feeling a bit of floatiness in the rear end, and shifts didn't seem as sharp as they could be, so I replaced my engine mounts with some Wevo semi-solids. I believe the Turbo at 80k miles was still on the originals and the difference was immediately noticeable. They add a dash of that "rawness" we 911 folk are always on about, and shifting is markedly improved, especially 1-2. Interior noise increased for sure but not excessively so, and in my opinion the extra NVH gives the car a bit more exotic excitement. Recommended upgrade, even if your OEM mounts are in good shape.
(FWIW, the originals [judging by the date code sticker and maintenance history] weren't completely shot but they were definitely stretched.)
#6966
Smile Vent, Center Rad Kit, and Grilles installed
Just completed the Center Radiator, Smile Vent, and Grilles install ... sweet! Damn I'm sore, just not as young as I used to be.
I had to make a template and then cut out air flow outlets in the lower portion of the bumper cover, mine did not pre-etched markings so i just went with simple.
And I will admit, it goes a lot easier if you can get it up off the ground, a lift would be perfect but if you don't have one (like me) getting the front up on Jack Stands so you can work with the front wheels off, makes removing and installing the inner fender covers so much better. And a real plus when dealing with installing the all the underside hardware.
Sometimes I'll do anything to avoid cutting the grass.
#6970
#6971
Did the annual brake fluid renew of Motul RBF600 in all the cars, including the 2 997s. I also converted my pickup over to it so I only have to stock one brake fluid for all the vehicles. The Cayenne will get converted when I install the PCCB upgrade in August. Pretty easy as I now have 3 different fluid reservoir adapters for the different brands of cars and have put a quick connect adapter on the Motive and the adapter hoses. I pour in 5-6 bottles of fluid and work my way around each car sucking out the old fluid from tge reservoir with a stainless turkey baster, refilling tge reservoir with new fluid, then hooking up the Motive to the reservoir, pressurizing to 20 psi, then hit each wheel starting with the one furthest from the reservoir and working my way to the one closest. The wheels on the cars ate open enough that I can get my silicone hose with mini ratchet setup on each caliper bleed nipple without having to remove any of the wheels, just roll the car forward or backward by hand a few inches if a wheel spoke happens to be in the way.
With the collection bag and clear silicone hose its a no-mess process and easy to see if any air bubbles come out. After each car, I empty the collection bag into a gallon jug and move on to the next car.
#6973
I don't do anything with what's left in the caliper bleed nipples - just put the cap back on. I guess I could touch a fresh Q-tip to the top to absorb the little fluid that's left in there, but my bleed nipples are stainless speed bleeders so I don't worry about fluid corroding the bleed nipple since the stainless is impervious to it.
At the end, I also take about 1 turkey baster of fluid out of the reservoir and put it back into the waste container since the Motive pretty much fills it to the top using it with the wet method where the fluid is in the Motive itself.
When I'm done with all of it, I spray brake cleaner though the silicone hose, then air to blow the cleaner out. I then do the same to the Motive pressure hoses and spray out the Motive container itself, dumping all that brake cleaner spray into the same container with the used brake cleaner. That goes to the recycling center and they have me pour it into the used motor oil container.
#6974
The reservoir seems to take most of a quart and then I run probably another 1/2 quart to a full quart through the system bleeding the 4 wheels, depending on how the color looks flowing into the clear bag. Since my 997s are .1s, I'll do the clutch slaves when I do the next oil change, but for that I do about 3 strokes of the clutch pedal. For the clutch, I hook up the Motive, but use a 2-person process. I open the bleeder, assistant slowly pushes the clutch 90% of the way down, holds it, I tighten the bleeder, they let the clutch back up (or pull it back up - don't remember), then repeat that process 2 more times. The Motive just gives me a little extra insurance that fluid can't flow in the wrong direction and that if lifting the pedal back up, that it sucks in new fluid.
Where did you get the stainless nipples?
#6975
