What did you do to your 997 today?
Old 12-12-2016, 06:29 PM
  #4936
AltVelo
AltVelo's Avatar
Royal Steering in the UK re-wrapped my sport steering wheel. I went with dark grey alcantara and beefed up the thickness to match XPA. The thickness of the stock sports wheel was too small and simply just didn't feel right at the thumb 9 and 3 o'clock thumb slots. The whole process took about 3 weeks including shipping.
i'm very happy with the thickness and workmanship. If this was the thickness I would not have re-wrapped it. Leather if fine but thought I might as well try out Alcantara. Initially it was a little strange but I think I'm going to like it.
AltVelo is offline
Old 12-12-2016, 06:49 PM
  #4937
metric91
metric91's Avatar
Originally Posted by jeffm
Finally wrapped up my front bumper! Spent months gathering parts and trying to do it with a budget in mind. Probably needed paint, but was surprised how well it cleaned up and did a touch up on the rest. Front lip was painted with plasti-dip for a nice matte finish. On to other projects!
Looks great. I recommend that you invest in some Dipcoat. It's a simple spray solution that applies much like trim dressing, this will remove the rubbery feeling Plastidip has.
https://www.amazon.com/DipYourCar-Di.../dp/B00S5D8F6U
metric91 is offline
Old 12-13-2016, 02:09 AM
  #4938
ALEV8
ALEV8's Avatar
Put my goddamn bumper back on realizing I bent my side marker clips and they're loose plus a busted headlamp washer elbow so that's 50$ and misc hardware to shore up my front bumper just so. Of course it has to come off again for the new headlamp washer sillies! I will scrub the living shttt outta those wheels and wells ala AMMO NYC.
ALEV8 is offline
Old 12-13-2016, 03:40 PM
  #4939
carrera4esq
carrera4esq's Avatar
Default Rear Alcantara in my GTS
Size:  293.9 KBThe 997 GTS's only came with Alcantara in the front portion of the car, the rear has full leather. It never looked right to me. So I purchased two interior rear quarters off Ebay for around $250 (I think they are around $1700 each new from Porsche,) brought it to my upholstery place where we matched the Alcantara and purchased original Porsche black carpeting and recovered the rear seats and quarters. Of course I have stored the original black leather quarters for originality. The job came out perfect. The lighting in the pictures does not do the job justice.
carrera4esq is offline
Old 12-13-2016, 05:46 PM
  #4940
tomc_mets
Sir Thomas Lord of All Mets Fans
tomc_mets's Avatar
^ That is the cat's meow.
Very nicely done.
T
tomc_mets is offline
Old 12-13-2016, 07:40 PM
  #4941
carrera4esq
Thank you. Some pics both cars when I traded in my C2s for the GTS.
Old 12-13-2016, 10:02 PM
  #4942
UK2
UK2's Avatar
I went retro today...installed wheels and snow tires from my old 996 C4S. The 996 wide body fitment isn't too bad on the NB 997S
UK2 is offline
Old 12-13-2016, 10:07 PM
  #4943
8202632
8202632's Avatar
what is waterless wash?!?!?!
8202632 is offline
Old 12-13-2016, 10:11 PM
  #4944
monster1
monster1's Avatar
Originally Posted by Gddrkrm
Guys how hard to install these buttons to gen1 car? Do I need 1m wire change?? And any risk about car brain confution ☺️
yes they can be changed - you just need to re-pin the connector. if you pm me I can give you detailed info.
monster1 is offline
Old 12-13-2016, 10:12 PM
  #4945
UK2
UK2's Avatar
Thats a random question for the "What did you do to your 997 today?" thread...but to give you an answer - it's a high lubricity pre-mixed spray detailer that is used to clean cars without rinsing. Thus being waterless...
UK2 is offline
Old 12-14-2016, 01:56 PM
  #4946
96Tiger
96Tiger's Avatar
Installed a new battery in my 2009 CS. It replaced the original Moll stamped 33 08. Can't believe a battery from 2008 lasted this long based on what I've read on rennlist.
96Tiger is offline
Old 12-14-2016, 03:21 PM
  #4947
jeffm
jeffm's Avatar
.....so I guess that would actually be "rinse-less", not "waterless"
jeffm is offline
Old 12-14-2016, 03:33 PM
  #4948
stoked_on_spool
stoked_on_spool's Avatar
Just purchased mine over the weekend! =)
2005 C2, manual, 49k miles, Nav, Bose, Heated power seats. Lowered on H&R springs, but will be replacing them with Carrera S springs shortly as the fronts are sagging quite a lot...
stoked_on_spool is offline
Old 12-14-2016, 04:00 PM
  #4949
tomc_mets
tomc_mets's Avatar
^ Tasty. Congrats!
T
Old 12-14-2016, 11:13 PM
  #4950
Pcar416
Pcar416's Avatar
^^ go for Eibach springs instead and you won't regret it
Pcar416 is offline
Quick Reply: What did you do to your 997 today?
