View Poll Results: did YOUR car suffer an IMS failure
Voters: 1661. You may not vote on this poll
IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
#1081
2005 997.1 M96.05, IMS failure around 90K. Failure happened in neutral coasting to a red light. The engine turned off with no load, made it to a parking lot, towed home and removed filter. Failure was determined via engine oil filter inspection. Everything was normal, no prior issues. Changed oil every 6 months. I owned for 1.5 years prior to failure. Once the engine was removed and disassembled, the single row bearing was the root cause. No other damage to engine besides the IMS housing gear, bearing itself, and IMS/Crank chain guide. All other components looked normal.
#1082
I just had the IMS bearing replaced in my 2005 C2 with 76k miles, and I kept the old bearing. The old bearing was still smooth rolling and looked great. It could have gone longer, but I wouldn’t have known that without pulling it.
#1087
997.2 doesn’t have an IMS. Porsche designed that out of the engine in 2009, so you’re in the clear. Only thing you need to be wary of is cylinder bore scoring which is less common in the .2 anyway so just drive and enjoy.
#1088
Cruisin'
Carreralicious (07-25-2021)
#1089
07 cabrio, 77k miles, no issues,
Not sure why this is still a sticky since the only failures I've seen on here (admittedly didn't read all 73 pages) are early production 05s. So tired of hearing about this non-issue on later 997s as being something to watch out for. At this point, if it fails on your 997, either you've got an early production 05, it was a one-off defective part, or it's just worn out from use (or perhaps some weird oiling issue?!). YMMV
#1090
#1091
This post helps to get other comments. I have a 2006 997.1S with 68,000 miles. I drive it on country roads the way we should drive a Porsche. This IMS bearing thing is on my mind to the point I'm thinking about getting a 997.2.
#1092
As you have the larger bearing in your car, I would not worry about it.
#1093
This nails it on the head, as does the prior comment demonstrate how awful this is. This feels like a sins of the father being visited on the son. The 997 IMS, after the early 05s, is flat out not anywhere near the issue it was for the 996s. Drive your car. Enjoy it. Keep your revs under 6k so when you go to sell it the other ******* crowd who freaks out about overrevs won't choke you. Or maybe just don't own a Porsche. They're designed to be driven, and hard. Ask Ferry (if you could).
#1095
My car is up for sale and all I get is constant questions of whether or not the IMS bearing has been replaced yet. When I try to explain to people the failure rate of the larger IMS bearing in an '07 Carrera S is almost nil, these Internet savvy buyers think the car is expected to explode at any moment. I wonder if this sticky helps or hinders the truth behind the "larger single roller IMS bearing" Does anyone have even a remote idea what the actual failure rate is on this car? I'm so sick of arguing with idiots!
