View Poll Results: did YOUR car suffer an IMS failure
Voters: 1659. You may not vote on this poll
IMS failure for your 997 car, Y or N? tell us (yr, 997.1, .2, m96, m97, failure mode)
#901
Correct, although like I mentioned previously I may have the exact date and milage slightly wrong since I do not have the records in front of me. The dealership was Porsche of Warrington PA
VIN: WP0AA299X5S717354
#903
Votes Yes.
Recently purchased a 997 (the 2nd one that I've owned) and found out after scouring through the service history that the car had the IMSB fail long back.
It's an early 997 (Nov 2004 build date I think) and the IMSB failed at 38,500 miles and was repaired by the dealership on 03/02/12.
This is actually a heave of relief for me, since they put in an LN IMSB kit and recently during the clutch change, the previous owner said that the bearing still looked fine.
#906
2008 997.1 s 179K miles. No ims failure
Daily driver. Warm climate. Replaced to AOS, which was scary cause smoke was pooring out back. Never torque or rev more then 3k before oil fully warm. Carefull of oil pressure going around clover leafs entering highway.
#907
High mile thread https://rennlist.com/forums/997-foru...age-997-a.html
#908
The clutch just failed on my '07 C4 cab, which I've owned from new and has 50,000 miles (I used to track it; hence, the clutch). The clutch/RMS is an expensive fix, and the dealer suggested they do the IMS upgrade while they had it apart. The IMS upgrade is only $1000, so I told them to go ahead. My recollection is that Porsche upgraded the IMS in late '07 MY or '08, so I've never been clear at how much risk I've been in any case. But for $1000, it's not worth taking a chance any longer.
#909
#910
#911
there is no IMS fix for an ‘07. The IMS bearings are the larger bearings in the crank. Possibly the mechanic doesn’t know which engine is in the 07, but he would have the crack the case open to get to the IMS on an 07. If you want to test his honesty, tell him to do it and then see if he comes back with good news.
#912
#913
#914
To all: Thanks for the info. Here is what they are quoting: LN IMS UPGRADE WITH TRANSMISSION REMOVED - $1,187.00
Is that informative at all? As my avatar suggests, I know early air-cooled Porsches fairly well, but on my 997 I have never attempted anything more complex than changing the oil or replacing the brakes.
Rich
Rich
#915
Rich
Rich
