A2DP and PCM 3.0 (bluetooth streaming)
#46
Thanks for the suggestion on the Tune2Air device. I got it today and it is simply awesome! Works flawlessly and even better is that the original ipod adapter cable for the 997 that does not have the USB connector works just fine. This means i can use the Tune2Air and charge the iPhone with the normal white usb charging cable!
#47
With the Tune 2 Air are you able to connect to both the phone (PCM bluetooth) and the audio (Tune 2 Air Blueooth) simultaneously? I have an iphone 5--seems like a perfect solution as long you do not lose the ability to make bluetooth phone calls.
#48
It looks like you can do both, but I've noticed that with my iPhone 4S, audio streaming over Bluetooth breaks up randomly. After unregisterimg my phone audio playback is now perfect. I'd be curious if anyone else is experiencing this problem with Tune2Air. I just installed so it might be a defective unit, or in need of a firmware update (apparently not a straightforward process).
#49
#50
#51
N1gels. It sounds like that forces the information through one Bluetooth stream instead of phone calls through phone Bluetooth and music through Tune2air?
I am waiting on my order. I will report how it acts on my '12 997s
#52
At first I thought the Bluetooth connection was weak, so I took my iPhone out of my pocket and put it on the seat, and then in the arm rest compartment next to the Tune2Air. This made no difference to the audio breaking up.
I have version 1.47 of the PCM software in my '09 997. It'll be interesting to compare notes when you receive your Tune2Air. Note that you need to be driving for the problem to manifest itself - it works fine when parked.
#53
As the PCM's bluetooth radio does not support audio playback over bluetooth (the protocol isn't supported by the PCM) I can imagine the pairing of the device with the PCM may be causing the device some heartburn if its trying to stream audio out over bluetooth to a PCM that doesn't support that connection type.
#54
I'm starting to wonder if it's actually an issue with the phone being simultaneously paired to two Bluetooth devices. My guess is that the phone is communicating signal strength information or other data to the PCM and this Bluetooth "multi-tasking" interrupts the audio streaming from the phone. It would be interesting to pair two phones in the car - one to the PCM over Bluetooth and one to the Tune2Air. If the problem isn't present, then its the phone that's having the problem.
#55
Agreed. That is indeed the state - audio is communicated via the hardwired connection to the PCM, and the phone via Bluetooth to the PCM.
That the phone is streaming audio via bluetooth to the dongle, which then sends it to the PCM is something oblivious to the PCM.
But the phone and the dongle need to be able to operate cleanly. So the phone needs to be able to maintain the two bluetooth connections simultaneously, and the dongle needs to be able focus on just the bluetooth connection to the phone and not get distracted by a PCM bluetooth signal.
#56
I have the same random short (maybe 1/10 of a second) disconnect problem.
It happens randomly and only when the phone is also paired to the PCM via Bluetooth.
I then plugged the Tune2Air into my 2006 BMW X3 (where I have a DICE kit) and it works flawlessly, none of these short spikes.
But nevertheless I would buy it again
#57
Ah, it's good to know it's not just my set up that behaves this way. I agree with you, it's great to have the ability to stream audio over Bluetooth, and for that it works really well.
#58
I was able to download the Firmware, but now I am waiting for a license code to install the Firmware...
I checked and I am on Firmware 3.2.0, here is the changelog for the latest versions:
V3.21 solves the issue :
Next track /Previous track doesn't work properly in some Mercedes (Head Unit A212-900-86-04) for Android phones.
V3.20 solves two issues as below :
1. The playback(next track/previous track/pause) doesn't work properly for Android phones.
2. The phone doesn't connect with tune2air when turning on the Bluetooth of the phone and pairing it with tune2air after left
tune2air power on for a while e.g. 20 minutes.
so I don't think upgrading to 3.2.1 will do much for me.
You can check your firmware version like this:
When your iPhone is paired with the Tune2Air:
Settings --> General --> ABout
Scroll Down and you should see an entry for TUNE2AIR
tap on it and you should see (amongst other things) the Firmware version
#59
I was finally able to contact the guys from ViseeO (who make the Tune2Air) to get my login. They have a Facebook page and seem to respond faster to Facebook messages.
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
#60
I finally was able to get my new Tune2Air device and my 2012 C2s in the same place for a while. It took me about 10 or 12 tries to get the T2A to connect with my iPhone 5. This was even after I removed the PCM connection in the phone's bluetooth memory list. Finally after connecting, I was able to use the phone as an iPod flawlessly. I really like being able to get in the car and have the music I want, though the USB drive worked well too.
I realized after a few minutes though that I did not have a cell phone connection through the PCM. I could try to make a call with the phone and the phone would ask if I wanted the T2A speaker to handle the call, but I could never move the check mark to put the call through the T2A.
I like having the phone auto connect with my PCM when I get in the car, so if I can't figure this out, I will go back to the USB drive or just go through the motions of hooking up the phone to the Y connect cord in the console to get the music i want. When I connect with the Y cord it gives me phone and music through the PCM
Anyone know what I might need to do to connect the phone through T2A?
