Fuchs Fuchs and more Fuchs
FYI; Suncoast has been running a special on a Porsche Fuchs wheel/tire/TMPS package
No affiliation. I have been considering these for my wife's 997.2 C4.
The Sep '10 issue of Excellence advertises new Fuchs rims at http://fuchsperformance.com
Here's a link on Ebay. I don't like them, too much of a "bling bling" deep dish. I am confused about the cast, forged, etc references. What is the difference between them all? I want the stongest and lightest wheel made.
http://cgi.ebay.com/ebaymotors/19-Fu...ht_2644wt_1160
Poseur
Poseur
The eBay wheels are made in China (no doubt) and weigh 28 lbs each up front and 35 lbs each for the rears!
If you want the strongest wheels you should await the Fuchs Racing FORGED wheels. A forged wheel benefits by the manufacturing process which keeps weight to a minimum and ensures a significantly higher strength over castings.
The reason the original Otto Fuchs wheels gained quickly in popularity with Porsche owners over the decades was not merely cosmetic appeal. It had to do with lighter weight and strength by being a forged wheel. Additionally, a forged wheel literally changes the shape of the aluminum molecules in a such a way as to orient the grain to benefit the strength of the wheel--castings can't do that. The molten material merely flows into a sand cast mode where it is both gravity and pressure acting upon it--it leaves a rougher finish (hence why cast wheels are mostly painted to hide that, or with limited machining to achieve the look inherent with forgings. Forged wheels can be polished much more than any casting, or anodized to give that characteristic Fuchs alloy look.
Cast wheels tend to fracture much more easily while a forged wheel will bend, perhaps, but not fracture. (Obviously, with sufficient force, it could also fracture but that is considerably rarer).
Here's an idea of what happens when you hit a curb with a cheap cast wheel:
