How To: Jacking up a 997 safely, securely
Old Jul 19, 2022 | 03:07 AM
  #121
Edgy01's Avatar
Edgy01
Poseur
Veteran: Army
Veteran: Air Force
Originally Posted by SAN997
I think this post is dangerous. There is only one correct way to jack up a 997, and that is at the four factory jack points. Anything else is risking damage. Get yourself a pair of Lift Bars or a set of Jack Point jack stands.
I've used these supposedly "safe" jack points as advised by internet experts before on an M3, and I noticed some structural deformation. Why do these internet Yahoos always know more than Porsche engineers??
As the original poster, I will obviously have to add that I have over 48 years with Porsche, and well in excess of 400,000 miles driving them. I’m mostly a 911 guy and have been working on my 911s since the late 70s. I am extremely familiar with the bottom of the various versions of 911, from the early 70s, to G models, to 964, 993, 996, 997, 991, and 992. Over the years Porsche AG has carefully designed jack points in an effort to both securely support the various versions, and also avoid collateral damage which can easily be done if you don’t know what you’re doing. I have also learned a lot from the various shops that I have had to employ when the job was beyond my wrenching capability—from Werk I in Zuffenhausen to California. (My brother in law has an 18 bay shop so I have seen and learned a lot about jacking up a 997.). I do not consider myself an “internet Yahoo” but I do seek to keep less experienced forum members safe and to avoid their accidentally bending things under there that best not be stressed. A BMW M3 is not a 911.
Old Mar 20, 2024 | 12:22 AM
  #122
Gg9591's Avatar
Gg9591
How is your Quickjack 5000 holding up? Do you have to do anything special before lifting the car? Any blocks needed at the jacking points?
Old Mar 20, 2024 | 12:54 PM
  #123
Recruiter_Bruno's Avatar
Recruiter_Bruno
It comes with two sizes of blocks. You position those under the 4 jackpoints and lift.
I usually lift an inch or two then walk around and inspect that I am directly on the jackpoints and then lift all the way up.
Such a great invention.
Old Mar 20, 2024 | 01:17 PM
  #124
Gg9591's Avatar
Gg9591
Thanks. I just got mine from Costco but have not set it up yet. I plan to do a lot of work on my 997.
Old Mar 21, 2024 | 09:52 AM
  #125
einstuck's Avatar
einstuck
I use these jack pads that slot into the jack points along with a Quickjack 5000 (which also works great with the Macan!). I also lift the car just an inch or so, double-check that everything is lined up OK, then continue to raise the car. Works great and minimizes physical labor.
Surprised however that nobody in the thread said anything about how tail-heavy the car seems even using the factory jack points. It's a bit spooky to me how much the nose can subtly bounce while working on things. I compensate by putting some spare parts and other heavy things in the frunk. Is it just me?
>inb4:"you're doing it wrong, einstuck!!!1"
No, doing it the same way as everyone else, with the same points. Maybe I should fill up the gas tank first?
Old Mar 21, 2024 | 04:55 PM
  #126
CBRich's Avatar
CBRich
Which direction do you face the QuickJack? I may be crazy or suicidal, but I've found it far more stable reversing the jacks seeing as how they're designed for a typical vehicle that is much more nose heavy than rear heavy. It got rid of all the lightness of the nose while jacked up.
Old Mar 21, 2024 | 08:46 PM
  #127
einstuck's Avatar
einstuck
Talking
Heh. I knew that!
(... is this forwards or backwards?)
Old Mar 21, 2024 | 10:47 PM
  #128
Recruiter_Bruno
I've shared this before but it never gets old....
My car:
Old Mar 21, 2024 | 11:26 PM
  #129
LucV's Avatar
LucV
Thats how Quickjack recommends to do it.
Old Feb 8, 2026 | 11:26 PM
  #130
MSW11's Avatar
MSW11
8th Gear
Great information to have at hand. Thanks everyone for sharing and making life easier
