PDK updates....
#91
Mine does have a little abrupt shift from 2nd to 1st in Sport as it changes to 1st before you really stop. I wouldn't say its a clunk by any stretch. In regular "auto" its almost like a Lexus as it only changes to 1st when the car is completely at a stop. In sport it goes into 1st earlier. Sometimes it feels a little jerky if you arent taking off right away (aggresively).
#92
I don't think "clunking or jerking" is what people are experiencing - at least not me. It is simply an abrupt downshift into 1st with what amounts to engine braking, which can seem harsh. I don't think most people in MTs and especially in ATs come to a stop like that. In an MT, I almost never shift to 1st until the car has come to a stop or at least I don't release the clutch in 1st when stopping. That is how Normal mode behaves, but Sport shifts to all gears, even 1st, at the "appropriate" time to maintain power.
If anyone is experiencing something more than a downshift to 1st - and the seemingly abrupt engine braking, then there's probably some other issue.
Otherwise I think it is by design - unlikely an oversight - and any fix would involve a re-thinking of the designed behavior. After 24 years of German cars and 10 years working with German software companies, I'm not holding my breath for that.
#93
#95
Mine too. And mine is a 2010. Built 6/09, so they had about a year to fix it at the factory.....
What I feel is as the car downshifts, the revs go up, so there's where I feel the jerking......
#98
here is the only tsb anyone has found
TSB: "WM 373025 ELIMINATING TRANSMISSION SYMPTOMS--RE-PROGRAMMING DME CONTROL UNIT AND PDK CONTROL UNIT (VEHICLE JERKING WHEN CHANGING GEAR)." The TSB was introduced on Sept. 5, 2008.
#100
It shifts into first just after coming to a stop. I usually have to manually shift it into first if I'm doing a "yield stop"... That said, I generally manually shift it into first at less than 10 mph.
#101
Hmm - how strange or how normal - not sure which. Definitely different from my car which always goes into 1st before I stop (in Sport Auto) - unless I do a panic stop. Thanks for the info.
#102
Mine also shifts into 1st before coming to a stop in Sport Auto - and i think the engine braking makes a little jerk (i'd suspect you'd get the same jerkiness in a manual if you didnt apply a little gas when you released the clutch).. Not sure how a PDK update will solve this unless in Sport Auto it only shifted into 1st when it stopped. Which is what it does in non-sport.
