Integrated Dry Sump Better?
Old Mar 9, 2005 | 01:27 AM
soltino's Avatar
soltino
Default Integrated Dry Sump Better?
Just picked up the Model Specific brochure for 997 and it states that there are "benifits" in this "internal" system.
Is this true with the possible exception of extreme racetrack applications?
tino
Old Mar 9, 2005 | 08:04 AM
Geza's Avatar
Geza
Reliability, for one. No external hoses or fittings to break, leak on hot exhaust manifolds and start engine fires. I find it quite interesting that a lot of people assume the integrated dry sump is not as good as the old external dry sump. As a mechanical design engineer, I'd give the Porsche engineers the benefit of the doubt until I sat down with one and had a lengthy conversation on the pros and cons of the integrated sump. Adapting an external dry sump to their race engines may be for purposes other than functional performace...maybe ease of maintanence...maybe increased oil volume...I don't know...but I wouldn't jump to conclusions.
Old Mar 9, 2005 | 09:15 AM
BD997's Avatar
BD997
whats that? which option??
Old Mar 9, 2005 | 08:36 PM
Sloth's Avatar
Sloth
Old Mar 9, 2005 | 09:27 PM
transduser's Avatar
transduser
5th Gear
The integrated dry sump system is a wet sump to me.
Old Mar 9, 2005 | 09:43 PM
TT Gasman's Avatar
TT Gasman
The new Ferrari 430 also features an "integrated sump" design in their engine, so maybe Porsche is on to something?
Old Mar 9, 2005 | 09:50 PM
soltino's Avatar
soltino
From the Brochure:
Dry-sump lubrication is race-proven technology that ensures a reliable supply of oil, while reducing engine operating temperatures.
A pump supplies oil from an internal resevoir located within the block to the lubrication points thoughout the engine. A futher pair of oil pumps--one in each bank of cylinders--then "scavenges" the oil and returns it to the resevoir.
This internal system offers a number of benefits compared with conventional external dry-sump tanks, including a reduction in both sysytem weight and oil volume.....
tino
Old Mar 9, 2005 | 10:10 PM
Moogle's Avatar
Moogle
i thought the M97 engined 997 were wet sump
Old Mar 9, 2005 | 10:32 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
Post
Yup, the only (true) dry sump engines are in the 996TT, GT2, GT3.....all from the same block/engine design.
Old Mar 9, 2005 | 11:37 PM
BD997's Avatar
BD997
inetersting...
Old Mar 9, 2005 | 11:41 PM
ben in lj's Avatar
ben in lj
inetersting...
yep, especially considering the misleading "integrated dry sump" on the 997 window sticker.
Old Mar 9, 2005 | 11:46 PM
MKW's Avatar
MKW
The problem with an integrated dry sump( still a wet sump ) assuming you can control oil pump starvation : the oil is still all stored right below the crank instead of in a separate reservoir , sloshing around and shifting with g forces so that the crank is sunjected to a lot of varying viscous friction.
Old Mar 10, 2005 | 01:56 AM
Moogle's Avatar
Moogle
thats very misleading
Old Mar 10, 2005 | 07:50 AM
Geza's Avatar
Geza
I'm not sure whether you've examined the engine drawings, or torn down an engine to take a close look at the oil system (I know I didn't), but in the movie "Split Second" on the Porsche USA website under 911 movies, they show a detailed computer animation of the internals of the engine, including the oil system. From that movie, it looks to me that the internal oil reservoir is completely seperated from the crankshaft; there appears to be a V-shaped baffle plate that prevents oil from sloshing onto the crankshaft.
Old Mar 10, 2005 | 10:27 AM
Gary R.'s Avatar
Gary R.
Yes, but did you notice that that they say "derived from racing" and that it assures lubrication even in "sporting driving style". Its that line between racing and sporty that they will get ya...
