Changed oil, car won’t start now
Old 12-21-2023, 01:45 PM
  #46
user 9089299
user 9089299's Avatar
Removed oil and refilled 7qts. Line is at the middle. Still won’t start. Video with sound attached: https://www.veed.io/view/c1c7137a-66...et=true&panel=
Old 12-21-2023, 01:48 PM
  #47
jchapura
jchapura's Avatar
@rojo33 Did the tachometer needle bounce when the engine was being cranked?
Old 12-21-2023, 02:16 PM
  #48
user 9089299
Fixed guys!!!!! Car was “flooded” I kept holding the throttle all the way down like I’ve done in my 993 and kept cranking until it turned on. It sounded like an airplane.
DesmoSD (12-21-2023)
Old 12-21-2023, 02:22 PM
  #49
jchapura
jchapura's Avatar
@rojo33 You should consider changing the spark plugs and coils.
Old 12-21-2023, 02:23 PM
  #50
Wayne Smith
Wayne Smith's Avatar
Received 1,209 Likes on 776 Posts
You work fast!!!!
Well done, and thank you for getting back to us. If you smell gas, then figure it's flooded.
What you did with the gas pedal is the old school method used with a carburetor. I'll admit I'm not quite sure how that works with an M9X motor. But it's good to know that's a solution.
Congrats!!!
Old 12-21-2023, 02:26 PM
  #51
Petza914
Petza914's Avatar
Received 6,603 Likes on 4,198 Posts
You may want to change your oil if you put enough fuel into it to smell it.
These cars have coolant temp sensors and lots of other electronics to manage how they start and run. You don't have to touch the gas pedal ever when starting them. If you do have to, there's another major problem.
Old 12-21-2023, 02:35 PM
  #52
Mike Murphy
Mike Murphy's Avatar
Received 1,728 Likes on 1,074 Posts
Weird. Not sure how the car became flooded, other than the old bad battery was not igniting the spark plugs due to low voltage.
In any event, glad that fixed it!
Old 12-21-2023, 02:37 PM
  #53
DesmoSD
DesmoSD's Avatar
How the heck did that happen in the first place?
Old 12-21-2023, 03:31 PM
  #54
PatrickBateman
PatrickBateman's Avatar
Definitely curious how this happened and how the throttle fixed it
Old 12-21-2023, 04:51 PM
  #55
user 9089299
im not sure why it happened but here are the things I did different
maybe overfilled oil
let oil drain for 3 days
didnt pull the fuel pump fuse.
let car sit outside for the first time ever in 20 degrees weather
been using trickle charger for a week
thank you all for your help, efforts and collaboration. Happy holidays! Picture of the flooded victim attached for reference
The following 5 users liked this post by user 9089299:
DesmoSD (12-22-2023), fourthirteen (12-21-2023), Goose 993 (12-21-2023), groovzilla (12-21-2023), TexRedC4S (12-21-2023)
Old 12-22-2023, 12:07 AM
  #56
DesmoSD
DesmoSD's Avatar
So does this mean that the title is a wash since it's now classified as a flooded car?
Old 12-22-2023, 02:11 PM
  #57
jchapura
jchapura's Avatar
Porsche forum folks, is there a recognized method to clear a perceived flooded engine (when away from home; no tools available)?
Old 12-22-2023, 03:02 PM
  #58
ADias
ADias's Avatar
This thread is the first time I hear about a flooded engine in a ECU controlled car. Very strange.
The following 2 users liked this post by ADias:
ATX_Native (12-22-2023), Mike Murphy (12-22-2023)
Old 12-22-2023, 03:48 PM
  #59
docdrs
docdrs's Avatar
To clear a flooded engine, a fully depressed gas pedal, sometimes the brake as well and crank the engine. This cuts the fuel pump but still turns the engine over to clear the fuel. It’s almost a universal way to clear a flooded on anything from a seadoo, boat , atv, car etc. it should be verified in the owners manual first. Also a way to prime the oil filter after an oil change so there is minimal bearing, journal, piston, cylinder etc wear on first start up.
Last edited by docdrs; 12-22-2023 at 08:07 PM. Reason: Missed the v, but not as in virgin
TerrestrialFlyte (12-25-2023)
Old 12-22-2023, 04:03 PM
  #60
Wayne Smith
Originally Posted by docdrs
To clear a flooded engine, a fully depressed gas pedal, sometimes the brake as well and crank the engine. This cuts the fuel pump but still turns the engine over to clear the fuel. It’s almost a universal way to clear a flooded on anything from a seadoo, boat , at car etc. it should be verified in the owners manual first. Also a way to prime the oil filter after an oil change so there is minimal bearing, journal, piston, cylinder etc wear on first start up.
Excellent information. You've explained a lot here. Thank you. Thank you. Thank you.
Quick Reply: Changed oil, car won’t start now
