How concerning is this?
#34
Engine replacement is about 27K, so car would be worth ~13K as is. These bore scored 997.1 cars have significantly reduced in market value.
Better to buy a higher mileage 997.2 that was cared for, in the 45K range, than a 30K 997.1 with a scored cylinder.
At 30K (purchase price) plus 27K (engine work), you are at 57K + range, and I don't think you can get 57K for a 997.1 with a rebuilt engine, unless GTS possibly.
If scored 997.1 bought at 13K, then with engine work at 27K (shipping or transport not included), you are at 40K, so a bit cheaper than 997.2 (high mileage) but should have a good 75K in front of it to enjoy.
Rig.Stunts (11-14-2023)
#35
+1. Not that it matters now that a BMW has been bought but I've seen a lot of inquiries like this where it's about a 997 as if they're all the same. For starters, big difference between 2005-2008 997's and 2009-2012 997's. Sure wish at least the model year of the car would be included where much more precise feedback could be provided.
#36
this makes sense, and has been a good learning experience for me. I am a 993 guy and had no clue. From my limited research bore scoring still happens in the 997.2, is this not true? He still wants a Porsche, but I think much more research will need to go into it, and he will need to find one that has been bullet proofed.
#38
I haven't seen any hard and fast statistics supporting this other than what's been said about it on this forum.
#40
Depends on what the block was sleeved with and who did it. Aside from cylinders, Mezger and the 9A1 and later don't have IMS failures. So sleeving a M9x block alone will not make it bulletproof.
#42
The 2006 and later IMS bearings have a very low failure rate. If a person was still concerned they could always add the LNE IMS solution to the rebuild. I’ve had the IMS Solution added to my 2005. The only issue, and I’ve heard this from others, is that the car leaks oil from the line that feeds oil to the bearing. I’m taking mine back to the installer to see if they can fix it.
#43
Using the IMS Aolution during a rebuild is the best choice.
#44
If I ever have to get mine rebuilt I'll definitely retain the oil-fed bearing.
#45
Seeing how often the topic of bore-scoring comes up on this forum, I am "surprised" we don't see a large number of 997.1 rollers.
Something to consider...
